Questions on initial bike prep.
I have noticed that most all of you recommend greasing various parts of a new bike as you think that the factory tends to skimp on these same areas. My questions are...
1) What exactly do you recommend to be done? (Grease headset, rear axle, swing arm...etc..) And what is involved, taking the back wheel off, removing the axle? What else do you have to remove, take apart, etc.. and are any special tools needed for this?
2) Would you recommend that a true mechanical novice attempt to complete the task? I mean, taking apart a brand new bike absolutely scares the crap out of me. The headset, axle, swingarm, wow!! With my luck, I would break something.
3) Does this really need to be done for all types of riding? Meaning, what if the bike is only going to be putted around by 33 year old novice?
Please keep in mind that I am an novice mechanic and a squid rider when responding.
It is really quit easy. No special tools needed. I can see where ,as a novice, you would be hesitant however. Make the job easy, tackle one area at a time. Start with the linkage. Remove the subframe and bottom shock mount. Take the linkage one at a time and apply a good grease. Take your time. Put it back together. Then remove the swingarm pivot bolt and lube the swingarm bearings. Put it back together! Then do the Steering shaft bearings. Just remove the top nut and top triple clamp and the whole assembly will come off wheel and all!! Lube the upper and lower bearing, put it back together and BAM!! The axels are easy just remove grease and re-assemble. Should take a couple hours max. Its good insurance. The factory only minimally lubes these areas with questionable quality grease and the bike is transported by boat from Japan. If you take your time even make sketches and notes you will have no problems, there are not that many parts envolved. You will get to know your bike and be proud of yourself for what you have done. Remember we were all novices at one time. You can buy a shop manual which will guide you if you desire. Good luck!! Welcome to the ranks
See you're scaring me already..."Remove the subframe and bottom shock mount".
Ouch!!! That sounds like a lot, and it would seem that I would have to take a lot off, just to do this (seat, rear fender, maybe even brake cables???).
Then with all the locations, do you just slap the new grease on? For instance, when doing the steering shaft once all has been removed (wheel, etc) do you grease the bearings in place, or do you remove the bearing rings and grease them and them put them back.
I would never do this without a shop manual, but even then it just seems like a daunting (sp?) task. Especially the linkage/removal of the subframe.
Arrrrgh. I am a pretty anal person, and I know it is going to bug the hell out of me if I don't do this, but at the same time, I know that I am going to just have fits tearing down a BRAND NEW bike that I am anxious to ride!!!! :D :D :)
The sub frame comes off with 4 bolts. One at the top by the top shock mount. 2 are down low by the swingarm and the last one is the back of the carb boot!! The fender stays on. The whole thing comes off as an assembly after you take the seat off. The airbox stays on. You can grease the bearings in place, just rub the grease in good. I like to use water proof grease. If you really do not want to attempt this ride it for awhile then take it to your local shop. I recommend you try at least the steering stem job, build some confidence then take it from there. I do not wish to scare you but if this is beyond you, adjusting your valves will down right freak you out. Nothing wrong with being aprehensive. You can also ask your shop if they would let you watch! Otherwise the shop or a friend in the area is it!!! I understand your position you spend $7,000.00 and you still cant ride. Ride it, just schedule the maintenance soon there after. There is grease in there from the factory. Nothing wrong with letting the shop do the work if you have the money. After all these thing do not require much maintenance other than the frequent oil changes and cleaning the air filter. Bottom line: I would take it to the shop after a good break in have them check your valves, re-grease the areas we have talked about then you will probaly be fine for a year!! depending, of course, on how much you ride. Good luck!!
  • Similar Content
    • By aminem
      my kill switch is not working and i had bought a new one , My problem is that , i cant disconnect the OEM kill switch . is it a trick to disconnect it !?
      plz Help
    • By Kevin from Wiseco
      Jeremy Martin Leads the Charge for Wiseco Riders at Daytona Supercross
      Christian Craig Turns in Career Best in 450 Competition
      MENTOR, Ohio (March 13, 2018) – Jeremy Martin showed the way for Wiseco-sponsored riders in Saturday night’s Monster Energy Daytona Supercross presented by Honda. In a season marred by bad luck and misfortune, Martin put together a near flawless ride to earn his first Eastern Regional 250SX Class podium finish of the season.
      Martin qualified eighth for the division’s annual visit to the World Center of Racing, finished fourth in his heat race, and came home second in the 250SX main event, missing his first win of the year by less than a second.
      “It’s Daytona, a real man’s track.” said Martin who sits fourth in points. “It was the toughest race of the year as far as fitness. I had to slow down a little bit, halfway through the main. I was getting close to (race winner) Jordon (Smith) and I was starting to think about where I could make a move on him, then I made some mistakes and he got away from me. Couldn’t quite get close again, but it’s good. We’re on the podium and in contention for wins again. That’s something I haven’t been able to say in supercross in a while. We want to get wins and now we know it’s coming.”
      Martin’s podium was a bright spot, but the rest of the event was rough for the GEICO Honda/Factory Connection squad. RJ Hampshire crashed hard in his heat race and had to be transported to a local hospital. He injured his back and ribs, but shoulder pain left him with the most concern.
      “I felt good on the bike all day,” said Hampshire via his Instagram account. “Had some pretty good speed and my foot just slid off hitting my shifter in those rollers during that heat race. After seeing the pictures from the crash I’m very thankful I didn’t take a shot to my head. I have some fractures in my T3/T4 in my back and ribs. Also have some damage to my lungs which is why I’ll be spending a couple nights in the hospital. I’ll be getting some more checkups this week on the shoulder also.”
      Cameron McAdoo, the third member of the team, was unable to compete at Daytona after being sidelined with a hand injury two races ago in Atlanta.
      Across the paddock, in the premier 450SX Class, Christian Craig got the call to fill in for Team Honda HRC. With the team’s regular riders Ken Roczen and Cole Seely out with injuries, it was up to Craig to carry the load for the factory team, and the upstart rider didn’t disappoint.
      The San Diego native was solid in both qualifying sessions, won his heat race and snagged the holeshot in the division’s main event. After relinquishing the lead to eventual winner Justin Brayton, Craig continued to show he was up for the challenge. The 26-year-old rider raced for second and third for most of the 20-minute-plus-one-lap feature before losing one more spot in the late goings to bring his No. 32 Honda CRF450R home fourth in the final rundown.
      “I had a great week testing with the team,” commented Craig. “They came down to Florida right after Atlanta and I feel like we really improved. Just getting more time on the bike and getting more comfortable was huge. I started off race day feeling really good. My qualifying position didn’t really show it, but overall I was happy with my riding. It’s all about having fun out there, and man, that’s what I did tonight. I was up front in the heat race, fell to third, but then the two guys in front took each other out so I ended up winning. You can call it luck or whatever, but I just put myself in a good position to capitalize on people’s mistakes."
      “I had a good gate pick and some confidence going into the main. I grabbed the holeshot and led for almost the first lap, but [Justin] Brayton got by me pretty quick. I stayed second for quite a while. I just rode my hardest and did my best. Unfortunately, a couple guys got by me so I ended up fourth. The track was so tough. This is only my second time racing Daytona and last year didn’t go well, so I really wanted to get some revenge this year. It’s better than the week before, but man, I was so close to a podium. I just need to keep putting myself in good positions and work on getting better each weekend.”
      Monster Energy AMA Supercross rolls on this weekend when the series visits the “Gateway to the West” for its annual race at the Dome at America’s Center in St. Louis. The 11th of 17 races on the 2018 supercross calendar will be televised live on FS1 Saturday, March 17, beginning at 8 p.m. Eastern Daylight Time, 5 p.m. Pacific.
    • By desert520sx
      I have a 03 450 that I just got and it runs great! I love my bike and am big on preventative maintenance. I have searched the threads on TT and have not found any descriptive threads on how to check valve clearance or adjust them. Just by looking at them, I can see that the intakes need to be shimmed and the exhaust valves can be adjusted quite easily unless one needs to be adjusted differently than the other.
      I tried to do it last night, and lined up the marks on each side to get the piston to TDC to check adjustments and could not get any readings on tolerances on either the intake nor the exhaust. I moved the crank a little bit forward and got a .011 reading on the exhaust valves. I read in a thread that the spec was .011" for the left one and .014" in the right for the auto decompressor. The spec I am using for the intakes is .006" Are these specs correct? :excuseme:The only issue is that the adjustment for the exhaust valves is one and the same. Different from my KTM where you can adjust each valve individually.
      No matter where the cam was on the intake valves, I could not get any readings. Does anyone have a thread, website, downloadable manual, or article on checking and adjusting valves in these beasts?
    • By Eric Schrader
      I am selling my 2007 Honda CRF 450-R which is set up for desert racing (Track/desert). It has an 18" rear tire with a heavy duty setup (see description for details). The bike screams and has a Tokyo mods carb mod with the 10x ignition mapping (currently set to a handlebar switch for smooth power and max power). Gas tank is a 3.2 gallon IMS dry break tank. V4 steering stabilizer included. Precision Concepts suspention, Bike is set up for 6'4" 175lb rider. Zero oil leaks and well maintained using a preventative maintenance method with the best new parts each time. Receipts for all items can be provided. About 20 hours on the rebuilt head. Carb just rebuilt. Starts cold in just 2-3 kicks. 100% reliable bike as long as you turn the gas on.  Current CA Red sticker and original title.
      Expand above to see details
    • By bigg_stevee
      I recently replaced water pump and seal after I noticed that my '02 CRF450R was spilling coolant on easy trail rides. After the water pump swap (which was successful), I noticed the same problem. It's interesting - the bike only spits coolant (I mean a LOT of coolant) after passing anything above 1/2 throttle. The bike makes this weird 'gurgling' noise, like trying to suck through a straw when your glass is almost empty. This is weird because I properly bled/ burped the radiators with coolant, and filled them to normal operating levels. The coolant spills through overflow hose.
      anyways - I swapped the radiator because I thought maybe the bike was running hot. I purchased oversized radiators, bought a 1.6 radiator cap (with a temp gauge) and bought engine ice. The bike runs very very cool - the temp gauge allows me to see this. Still, the bike shoots coolant out of the overflow after going above half throttle, making the same weird gurgling noise when it does. Bike has all of its power, top end was replaced not too long ago.
      I'm lost and don't know what is wrong with the cooling system in my bike. How do I make the bike stop shooting out coolant, and stop making the weird gurgle noise??? Any advice would help me!!! Thank you!
