28th Annual SNOW CHICKEN
Attention Michigan riders.
This Saturday at Peacock Motorsports near Baldwin Michigan is the Snow Chicken. Its a 45 mile trailride in the snow. Ya can run Quads or bikes. But Studs will be required cause its gonna be slippery.
It starts Saturday at 10:00. $10 signup fee.
Get outta the house and ride.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
