A couple of questions for all you smart guys
1. When I purchased my bike (used 01 400) the bike already had a weld mounted Scotts Damper post. I of course used that as a great excuse to buy a damper for it :) The question is, if I change to 18MM offset clamps will the post still work in its currently mounted position? Would be tough to move it. Also, since it is welded on, can I still move my handlebars forward and back for comfort or am I confined to the current setup?
2. My old bike (00 380EXC) had pro tapers and I had the EE style handguards. The new bike has the gold stock bars (I guess they are Maguras) and the handguard clamps from the old bike don't seem to fit right...I guess I thought the tapers on Maguras and Pro Tapers were the same. Are they different? Do I need different clamps?
Thanks guys, I look forward to your responses.
The pivot on the damper needs to line up over the center of the stem. When in doubt call Scott's, they've seen it all!
I just put Motonation Wackers on my 2003 EXC, they use diffent clamp kits for Magura and ProTaper.
If you want to move your bars to a different position you have to buy a different top bar clamp. The difference in the four offset positions is the location the mounting holes and grove for the dampener that are machined into the top bar clamp.
When I bought my 18mm offset clamp set I bought the Scotts because I already had their dampener and I wanted to be certain everything lined up.
Other brands of clamps may do this as well but I only wanted to have to call one place (Scotts) if I had a problem.
The hand guard clamps are different between magura and pro taper. You need the proper clamps for your bar. The pro taper clamps will mount to the maguras but will move too easy.
Instead of buying different hand guard clamps from EE for a different bar, you can do as I've done and mount the inside of your handguards to mounts that go to the pinch bolts on the top of your aftermarket top triple clamp. Its a more secure way to mount the handguards IMO.
Hi Chris,
This is my old bike so I know the answers. :) Remember that the damper has to remain lined up over the center of the steering stem no matter what triple clamps or bar position you use. That's why you have to buy a different top bar clamp if you want to move your bars forward or backwards. When you keep that in mind, you can see that the tower and damper relationship stays constant no matter what. So, no, you will not have to move the tower. I used that tower for my Scott's damper with both the stock clamps and the 18mm Scott's that I had on the bike.
There's a cool top clamp over at http://www.dirttricks.com that will accept the damper for any of the four stock KTM handlebar location, BTW.
If you do get 18's, make sure they have the pinch bolts in front, like the Scott's, so you can run the inner BB mounts that ditchwitch is talking about. That's the same setup I ran on it.
  • Similar Content
    • By Ponch
      I have a 2007 450 EXC that I recently installed a new clutch slave cylinder on. Per the 2007 KTM service manual it clearly states that the clutch needs to be filled with hydraulic oil, which I did (magura blood). That was yesterday. I went out to double check the level today and when I removed the cover, the rubber seal was all contorted and out of shape. I then looked at the cover and it's a Brembo clutch and says "DOT 4 brake fluid only".
      I flushed the line and the master cylinder about 7 times with DOT 4 brake fluid and there was no sign of the magura blood left in the system. My question is: other than the rubber boot on the master cylinder, what damage might have been done by putting in the hydraulic oil? It was in for about 24 hours.
      Thanks in advance for any advice!
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
