shock spring?
85-111/250 stamped on it, does anyone know what this is?
Came off a 520.
It's a PDS4 (8.5/11.0). The last number is length in mm. The PDS springs are measured at 20mm (compressed) which is called "C1" & at 100mm compressed which is called "C2".
PDS-0=6.5/8.3
PDS-1=7.0/9.0
PDS-2=7.5/9.7
PDS-3=8.0/10.3
PDS-4=8.5/11.0
PDS-5=6.6/8.6
PDS-6=7.15/9.05
PDS-7=7.6/9.5
PDS-8=8.1/9.95
Also note that the PDS-5 thru 8 are 260mm long. PDS 0-4 are 250mm long.
Jeb, where do you get this stuff, man? :) This is why I'm so happy with going orange, no matter what you ask someone knows more about it than you would ever want to know!
I save it from older posts in .txt files and pull it out when needed to make myself look smart. I'm long in the tooth on the KTM forums, I'm afraid. :)
thanks Jeb. Would this be the correct spring
for fast woods riding? Weight is #225 less gear.
525exc.
Yes, it should be just about right on the money for you. If you ride slower, rough stuff all the time, a PDS3 or PDS8 might give you a little plusher ride.
thanks jeb, what do you recommend for front springs?
.46 or .48, depending on terrain and speeds you ride at.
