Rumored RM450F
Hey has anyone heared any rumors about this bike. The joint venture with Kawasaki and Suzuki have teamed up.Any pic or feed back would be nice.
A pic was posted about a week ago. Look back a few days and you'll find it.
There were very fake looking pics of the RMF250 and the Kawasaki 400. I'm hearing from the dealers that I know that the 250 is due in august and the 450 Suzuki that will be my next supermoto bike will be out in September. I have seen no real pics yet.
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
