Dynojet kit installed but something is not right ?
well I adjusted the fuel screw out 2.5 instead of 3.5 and repacked the upper of the carb, will see tomarrow if that helps. Turning the fuel screw in does what? leans? And what is the third jet in the bottom of the carb I think it reads 66.5 or something?
Thanks burned. I triple checked that clip and it is on the fourth clip from the top. One thing, when the slide is assembled the needle has tension on it and I can push the needle in about 1-2mm and the spring pushes it back out, does that sound right?
(clip)had to use the stock (big) spring...the one that came with the kit would'nt fit. It was alot skinnier that the stock and kept folding over when I tried to replace the cap on the carb.
What about that spring? I just started to install one in my bike and have noticed the same problem. ?
