My speedometer is not reading correctly.
My speedometer is reading in half increments, like say if I'm going 40mph it will read around 20mph. I noticed that when I bought my bike the speedo cable was kinda kinked, but I didn't have any trouble with it until 1600 miles later. I was thinking maybe I put the front tire on wrong were it connects with the hub and the speedo, but haven't checked it yet. I hope its not an electrical problem.
Anyone else ever had any similiar problems?
Maybe you're just slower than you thought! :):D
The only problem I've had with the speedometer is trying to believe what it shows. It's gotta be off by at least 10% :)
"My speedometer is not reading correctly" - Try phonics :)
The front wheel has to stay on the ground for the speedometer to work properly. :D
Maybe slow down, and ride it like you own it. :)
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
