SETTING ROCKER ARM AXIAL PLAY???
how do i set it? Jeb had a link on his website but it wasn't specific as to what nut/bolt that you loosen/tighten to adjust it at least not judging from the pictures that he had from the manual
I believe you loosen the bolts next to the spark plug, then with the valve covers off, slip in your feeler gage and tighten down the bolts.
It's the two 55mm bolts in the link. The link is in the 2nd link in my sig. With those two bolts loose, you can move the rockers on the shafts. You may have to push on them a bit depending on where the cam is at. You need to have some gap between the rocker and the head/end piece.
