Still having problems starting the YZ450!!
I'm ready to give up. My 426 really spoiled me. First or second kick every time no matter how many times it flipped, how cold it was, or what ever....This 450 takes 10-20 kicks when it is cold. Here is what I have tried:
1. 2-3 twistes on the throttle, no choke and kick. Tries to start but still takes 10-20 kicks to start.
2. no twists, no choke and kick. 10-20 kicks to start.
3. The above two with the choke and kick. 10-20 kicks to start.
4. Hot start pulled (again this is all when cold)5-10 kicks to start.
The air filter is spottless along with the airbox tubes (not sure what they are called), the carb was cleaned ( brand new, it wasn't dirty or clogged ). At a fast idol, I tunned the fuel screw out 2 1/4 turns. The plug is greyish tan. No backfiring occures on deacceleration. At 1 3/4 -2 turns out on the fuel screw, the bike would run lean and backfire. All other jets and settings are factory.
Even when the bike is hot, starting it is very inconsistant. Most of the time it starts up within a couple of kicks then sometimes it takes 10-20. Once running, the bike rips!!
I live in south Florida, humidity is high along with the temp. Any help would be greatly appreciated!!! :)
Some one will come along and give you better instuctions than this but I think you need a smaller pilot jet. Anytime you run your fuel screw at more than 2 turns out you run the risk of losing it. Drop down one size on your pilot jet and maybe someone can tell you what air jet to run because I don't know. If that doesn't work it might be something electrical, but I can't help you at all when it comes to that.
The 250F guys are having CDi problems...wonder if yours may be bad as well?
How many hours on the bike? Replace the spark plug, replace old fuel in cans with fresh fuel, clean air filter and adjust the fuel/air mixture screw. Normally, the bike will start within three kicks when the temperature is above 50 degrees. When the temperature is below 50 degrees it may take 10-15 kicks to start. When it is warm the hot start isn't always needed. Kick once or twice without the hot start, then if it doesn't start use the hot start.
It might be worth checking the valve clearance,especially if it's erratic starting. It's possible they might have been a little off from the factory. Not likely on the yzf's but it can cause the problems you describe. Worth a check and a minor adjustment if needed.
If the bike would start in 2-3 kicks in warm weather if you went to the next size up pilot when cold it should start in 2-3 kicks also. As of yesterday I experimented with every pilot from 48,45,42 & 40. The bike would start well with any of them! I am going to a 38. I just switched to the EJP needle and have to change everything else. But I will get there soon (this weekend). I am sure it will rip again!
If you make the pilot circuit rich, will it effect the 0 - 1/8 throttle when warm?
So bottom line, do you guys think the bike is too rich? Is this why I can start the bike easier when I pull the hot start (warm or cold)?? Doesn't the hot start lean out the carb??
So go down one size on the pilot jet.
Check the valve clearance.
Maybe, go down one on the needle clip.
Does this sound right??
I am not the most knowledgable person, but doesn't the choke richen the mixture, to make it start easier because the gas will stick to the cylinder wall because of condinsation. Now if that is the cause and the bike is running that rich, wouldn't the bike run like CRRRAAAPP spitting and sputtering while running. I think its the valves.
No where in your starting methods do you mention NO twists of the throttle and choke ON. First stop twisting the throttle, 2-3 twists is MOST CERTAINLY flooding that carb/motor. Second if it's cold the thing will not be easy to start with the choke off.
Here is how I start my 450 and from the first start, until now I have not ever kicked more than 3 times:
COLD: choke on, kick NO THROTTLE TWISTS AT ALL (unless I let it run with the petcock off at the end of a ride, then I twist ONCE to prime the carb)
HOT: Choke off, and kick. I don't even use my hotstart lever, it starts without it
HOT and if I stalled it: choke off, kick. Again I don't use the hotstart lever.
Of course also follow the advice of others and make sure that your plug and all has been changed properly.
Oh by the way you need a richer pilot jet, you shouldn't be more than 2 turns out on your fuel screw.
I know you have your 426... but.....
did you slap on afreshly oil air filter and start it? or have you started your bike after you just washed it? If you answer yes to any of the two questions.
You might have clogged the slow jet. Time to clean all the carb jets.
No problems in So-Cal EVER (99 400YZF, 02-250F, 03-450F)
btw, i am having problems starting my Red Machine? any helpful ideas? to much compression I think........
Yeh, In all the frustration, I just forgot to add that part about not giving it any twists. I did that too. Like I said, it seems the only way it will start is by pulling the hot start lever in. So you think I should go up one size on the pilot jet? Here's the bad thing about owning a two stroke and a four stroke. I start confusing myself on what does what. :)
No, I sold my 426 to get the 450. The 450 is 10 times the bike, if only I can get the starting thing under control....
Whenever I have tried to start my 450 with the choke on it won't start until I pull the hot start once and let off then kick it and it starts right up? I'm like you nothing, but 2 strokers before and I am still learning the basics of a 4 stroker. Going to take my bike over to a seasoned 4 stroker and he will set it up for me and school me in the process.I know I use the hot start more than what's needed, but hey it starts! Then the fun begins. I bought the power now, but am going to have this guy instal it so it all jetted right. Wouldn't trade the 450's hit or raw power for anything. This bikes a blast!!!!!!!!!!!!!!. JUST PIN IT!
03 450, works frame guards, acerbis, power now
Once you get the knack this will work all the time.
It's 30 degrees out bike hasn't started for 2 days.
Turn gas on,Choke, Hot start pulled in,
No twisting throttle.Dont just flat out try to kick the snot out of it,,That wont work.
Try this technique, Just try it.
Kick half way down,then up,
then one full kick in one fluid motion all the way down.
It's kinda like a pre-prime kick.
If that doesn't work then try the other clues that are posted.. But I think it'll work. :)
It works for the Baby-F every time,even when I dump it.
Sometimes after it's warm I dont even have to kick a full kick to get it lit,just half.
See Ya,
If you are having to pull the hot start to start it even when the motor is cold it needs to be leaner. Go down 1-2 sizes with your pilot and it should resemble what you are doing now with the hot start. The power now is a simple installation. You shouldnt have to have anyone install it. Jetting is a little bit of a time consuming process but once you understand it,the knowledge is invaluable. It shouldnt take you but 10-15 minutes even if you have to pull the carb off after you do it a few times. You can remove the carb with out removing any body work or the seat.
I start my 250F the same way I started my 96 CR250 after it has been sitting for a week (in the garage).
I turn on the petcock, pull out the choke, lean it over until fuel runs out of the carb overflow, and kick it with NO THROTTLE.
Usually starts 1st or 2nd kick everytime.
Try that before you go messing with the jets.
Let us know if that works.
Have you changed your plug? I just fouled a plug last night that had only .6 hours on it. ( Yamaha hour meter helps with maintenance intervals) I took it out and it had spark. I guess just not enough to spark the fuel. I installed an new plug and one kick later it was running. Might be a cheap fix for all your headaches.
fatmancantfly, now that you mention it, the stock plug that came in my bike lasted about 2 rides.
It crapped out before we could start our 3rd ride. Couldn't get the bike started.
Been using SPLITFIRES ever since with no problems.
I had to go up a size on the PJ and richen up the clip because of a new exhaust,because of popping,crackling,backfiring. :)
Sometimes I dont even have to kick it hard at all,just fall on the lever a few times real slow and it'll start. :D (cold) I'm confused.
As to jetting this bike?
It sure is alot easier than the Red one, IMO.
Access,I mean.
Thanks Fastest1, for your info.
I was alittle confused cause everyone around here was richening their PJ's by 2 sizes except me.
I just always started my bike with the Hot Start pulled. :D
Maybe I should try it without. I dont think I have.
I'm going to check it out now.
And what's the benefits of the Power Now thing? and why?
Thanks in advance. :D
See Ya.
  • Similar Content
    • By Samx22x
      Alright so I’m new to the site so maybe this question has already been asked. I have a 2002 Yz426f and I want a new exhaust, it has the stock header and silencer and sounds amazing but I’d like a little more from it, I know I want the fmf power bomb header and am kind of undecided on the silencer, I see on fmf’s website that their silencer will add low end and slightly take from top end and the other way around but I’m looking for increases throughout rpm range. I do a lot of trail, hill climbs, jumps, and wheelies so kind of need good performance everywhere in the rpms. My question is what silencer I should get and the jetting I should get for the carb. Thanks
    • By Zack Ailing
      hey guys just picked up a new project bike. Its a 2008 Yz450f with a big bore kit and a stroker crank. The total cc of the engine is now 499. It runs on race gas and will be an absolute monster when shes ready to rip. I will continue to make more videos on the bike so stay tuned Link to the video:
    • By High On Octane
      2005 YZ450F, Athena Big Bore, Power Bomb, Q4.
      Ok.  Last fall after a decently hot day at the track, I noticed coolant leaking from the weep hole on my water pump after pulling into the pits.  Ordered an Athena re-seal kit, put it all back together and didn't really get a chance to ride it.  3 weeks ago, went out to the track, and after about 20 laps, it started leaking again.  Kept filling it with water to get thru the day, never ran anywhere close to dry or empty, jut a cup or 2 low.  Ordered a Hot Rods re-seal kit with bearing and also ordered a new w/p shaft.  Did it all again and got it back together, ran it, and as soon as it got to temp, it was leaking out of the weep hole again.
      So, what the heck am I missing?  I'm totally stumped on this one.  Is something wrong with my case cover?  Do I need to replace the w/p itself?  I'm feeling like I should've just ponied up for the Boysen in the first place, and now it's biting me in the butt.  Any help or suggestions is greatly appreciated.  Thanks!
    • By Awheeler25u
      Alright guys, my 04 YZ450f runs fine minus some slight backfires when decelerating (need to adjust fuel screw). The other day when I was done checking my valve clearances I changed the oil and filter and put the bike back on the stand, kicked it a few times without the ignition coil in to get some oil flowing got off and noticed a little drip spot on the ground, it was no bigger than a dime so I thought nothing of it. Started the bike with no issues took it for a quick 10-15 min ride, came back to the garage to find out my whole case was soaked with oil and it started pooling in the low spots on the clutch basket side. I cleaned all the oil off and took it out again for 5 mins to try and see where it was coming from, here are my three possible places but nothing directly leads me to believe it’s any of the three either.
      1. Decompression plug area
      2.  Valve cover gasket leak (not really sure because the amount of oil leaking Looks to be a large amount
      3. Oil tank (bad weld or cracked weld somewhere
      what are you guys thinking?
    • By bofar
      Hey guys. I could really use your help diagnosing an issue that came up riding today. Bike is a 2013 YZ450F. Well maintained and haven't had any issues until now. Both the oil and coolant are new and levels are to spec.
      After riding for about an hour in the sand dunes, I noticed a grinding going on on the right side of the bottom end (from what I could tell). When I looked to see what was going on my kickstarter was vibrating and grinding really loud. This was a different sound than if you engaged the kickstarter while running. It sounded less "clanky" and more "vibrating/grinding" if that makes sense. Grabbing the kickstarter and moving it didn't help the issue.
      When I noticed it, I shut the bike off and gave it a second. Being a few miles deep into the dunes, I had to get it out of there so I started it back up and it seemed fine- no grinding. I headed back to the car and after a few minutes, it came back so I shut it off again, started it back up and nothing. That process happened one or two more times before I made it back to the truck. Seemed to run fine otherwise.
      Once I got it back to the truck I started it up and tried to pay more attention to what was going on but it wasn't doing it. I did seem to have more of a metal on metal noise coming from the motor. I started and stopped the bike a few times and after the motor stopped there was a distinct metal clank/grinding noise that happened right after the motor shut of for maybe half a second. This doesn't happen every time.
      I tried doing some research and have seen things that make me think it could be the spring that connects to the kickstarter, or the kickstarter stopper plate- but really I have no idea.
      Seems strange that the issue is off and on.
      Thanks for the help!
