what stock chain on DRZ-S?
RK or DID??
From the specs in the owners manual
RK520KZO, 112 Links
Thanks pal. :)
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
