Let's swap radiator shrouds!
I've got 2 left side radiator shrouds sitting in my garage and I need a right. If I buy another set, I'll have 3 lefts! Why can't I alternate crashes so I damage one side then the other and not the same side twice in a row? :)
Is anybody else in a similiar predicament but have 2 RIGHT spares and need a left? Let's swap. To recap: I need a right side shroud. Do you need a left? (Oh, I need the yellow one) Thanks.
what color, i might be in the market to buy one off of ya.
I have a set of stock white. I just put on Black. :)
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
