Forks change after about 10 - 15 mins of riding
Wonder if any of you can help, after having my suspension revalved and setup they change the way they work after about 10 - 15 mins on the track they go from working 100% to skipping on corners and not handling bumps very well any idea's
when it starts to act up pull of the track, put the bike on the stand so the front wheel is off the ground, then loosen the air bleed screw, if you have excessive pressure in the forks your suspension guy messed up, he could of valved the forks wrong, there are many reasons why this could happen but that is the best place to start.
