Helmetcamera.com users
Anyone found a second source for the "velcro" they use in their
"extreme" kit?
$3.50 a pop sounds a little pricey to me...
Go to Radio Shack and ask for "loop to loop" velcro. If they dont know what it is go to the velcro section and you will see it. (the pimply faced kids dont know much :))
Although, Im not sure what you mean by "extreme kit", I assume you are talking about the velcro that attaches the cam to the helmet?
They have two different mounting systems, one for the goggle
strap, and one they call the "extreme" mount... it's velcroed
to the side of your helmet.
I'll go to RS today, thanks for the tip!
I have not yet found a second source for the velcro, please let us know if you find the same stuff!
MOmilkman, if you've never seen the velcro that comes with the camera, it is STRONG stuff! I lift my helmet by the velcro'd on helmet camera and shake it around and it won't pop off of the helmet. :)
What is some of the ways you guys have your Cam system setup? I am still experminting with the best way to hold the cam, cables, mic mount, etc. I have tried the cam in the camel back, and the fanny pack, not real happy with either.
I have found the best place for the mic is high on the chin strap, inside helmt, so you don't get the wind buffing sound, just the sound of the bike or any comments you would like to add.
I know exactly what hes refering to.
I used to have a helmet cam (since sold it) and I could hardly rip the camera off the helmet with it.
Radio Shack has this stuff. Its called "loop to loop velcro". Not the traditional "loop to fuzz stuff".
We're still experimenting. Last time out we used a small
backpack to hold the camera and ran the wires up to the
helmet from behind. We tried a couple of different mic setups:
1) Clipped to backpack. Lots of wind noise and no verbal commentary.
2) Clipped to front of jersey. Lots of wind noise but had pretty
cool realtime commentary.
3) Clipped inside helmet. Not so much wind noise, but my heavy
breathing after 3 laps was pretty embarrassing. :)
While I'm at RS today, I'm going to look for some mic foam too.
That should reduce the wind noise quite a bit.
On a side note: Anybody know anything about the remote stop/start
switch (not the IR remote)?
Merfman, Yes I did get the one from Helmetcam.com. It works great, it has a LED light so you know when your on standby (Green) or record (Red). the problem is its another wire you have to deal with, I have been using a small velcro strap and threading it through my chest protector in the front.
Thanks for the RS tip, I'm surprised they have that stuff. I'll have to check it out!
My cam setup; I wear a fanny bag but I wear it on the front for safety, though I'm not convinced this is really safer since my last crash was a belly flop. If you take a small sandwitch baggie, cut a small piece of it out and wrap it around the mic and then use a tiny zip-tie to hold it in place, then this really cuts down on the wind noise a lot! I've also had great luck wearing the mic on my belt behind me.
I want to try a new camera position next time I'm at the track. I want to mount the camera under my left radiator. You get a stellar view of the front tire that way! I tried it in the garage using zip ties and it looks very solid but I haven't tried it at the track yet. I jumped up and down on the bike and then watched the video and you get a great view of the front suspension working but the wheel is off to the side so you still get a clear view of the track. The trick is that the helmet camera, battery and mic need to be attached to the bike, with only the RCA connectors connecting you to the bike. This way if you fall it will just unplug. I'm going to try it next time I'm at the track. :)
I also use a fanny pack and ride with the camera in front of me. Tuck&Roll baby if I have to get off. The camera is mounted on the side of my helmet. I have video on my work PC for times things are slow at work.
From experience, the tuck and roll idea sounds good but doesn't work too good. :) When I did my belly flop I landed all out of whack from a jump and I was face first in the dirt before I even realized that the wheels had touched the ground. :D I guess there's no real "safe" way to do it unless the video camera is mounted to the bike itself. Though I'm sure the camera wouldn't last many rides like that..
Padded fanny pack with two compartments, microphone in the fanny pack with wind screen (also purchased at Radio Shack), and goggle mount/velcro lipstick camera connection. All that I hear on the tape is the bike unless we stop riding, then I can hear our conversation. Unless if you are riding in an area that needs a lot of explaining, there is no reason to use the microphone for commentary.
  • Similar Content
    • By yz480doinwork
      Brand new, still in the packaging Lexx end cap fits the stock muffler of 2006 & 2007 YZ450f and 06-13 YZ250f. Comes with a forest service approved spark arrestor and two different size tips. Don't spend hundreds of dollars on a slip on, this tip can be quiet and forest legal or loud and make power! Also a note for WR450 guys: get this tip and find a used 06/07 YZ muffler, fits directly on 09-15 WR450. $80 shipped free to the lower 48. PM, call or text 406-223-8789
    • By Woody Oakson
      So I have a 2008 yz450f and I would like to add some LED lights to it to make it street legal. Mainly just a headlight and a tail light and turn signals if I need to (which where I live hand signals work).
      So where I need help is getting power from the stator to a battery. Wiring from a battery to anything else I got and understand and don't need help with (but recommendations are welcome). So my questions are.
      What type of power is coming from the stator. AC or DC? Will I need a regulator or rectifier? How do I wire something from the stator to charge a battery? What would that wiring look like? Would this stator http://www.rickystator.com/product/stators/yamaha/yamaha-yz450f-35-watt-lighting-stator-assembly-06-09 work? Anything else I should know? Any help would be appreciated. Thank you.
    • By Samx22x
      Alright so I’m new to the site so maybe this question has already been asked. I have a 2002 Yz426f and I want a new exhaust, it has the stock header and silencer and sounds amazing but I’d like a little more from it, I know I want the fmf power bomb header and am kind of undecided on the silencer, I see on fmf’s website that their silencer will add low end and slightly take from top end and the other way around but I’m looking for increases throughout rpm range. I do a lot of trail, hill climbs, jumps, and wheelies so kind of need good performance everywhere in the rpms. My question is what silencer I should get and the jetting I should get for the carb. Thanks
    • By Zack Ailing
      hey guys just picked up a new project bike. Its a 2008 Yz450f with a big bore kit and a stroker crank. The total cc of the engine is now 499. It runs on race gas and will be an absolute monster when shes ready to rip. I will continue to make more videos on the bike so stay tuned Link to the video:
    • By High On Octane
      2005 YZ450F, Athena Big Bore, Power Bomb, Q4.
      Ok.  Last fall after a decently hot day at the track, I noticed coolant leaking from the weep hole on my water pump after pulling into the pits.  Ordered an Athena re-seal kit, put it all back together and didn't really get a chance to ride it.  3 weeks ago, went out to the track, and after about 20 laps, it started leaking again.  Kept filling it with water to get thru the day, never ran anywhere close to dry or empty, jut a cup or 2 low.  Ordered a Hot Rods re-seal kit with bearing and also ordered a new w/p shaft.  Did it all again and got it back together, ran it, and as soon as it got to temp, it was leaking out of the weep hole again.
      So, what the heck am I missing?  I'm totally stumped on this one.  Is something wrong with my case cover?  Do I need to replace the w/p itself?  I'm feeling like I should've just ponied up for the Boysen in the first place, and now it's biting me in the butt.  Any help or suggestions is greatly appreciated.  Thanks!
