Seat Cover Dilemma
I have been trying to install my new gripper seat cover, putting it on and stretching it tight is not a problem. I just can’t find a good way to staple it on! Both electric and Manual staple guns wont work? The staples just twist up or wont go through the seat plastic. I have already looked at Pneumatic staple guns at Sears and Home Boy Depot, but they (Air Staple Guns) don’t have, or I haven’t found yet, 1/4 shallow staples. Sears’s shortest staples are 1/2" 20 Gauge 3/8' staples, those are too long.
What have you guys used with success?
I used an electric stapler, I think it was Arrow. I had to hold the stapler down very tight against the seat (push down hard) to get it to work. Try to keep the stapler straight as possible. Any movement in the stapler will cause them to twist. It was a PITA, but I got it to work. Be careful near the thin parts because you don't want the staples popping through the seat cover. I think I used 1/4" and 5/16" staples. Good Luck
A pneumatic staple gun, 120psi will put a staple through anything. :)
I actually just got my gripper seat cover installed last weekend. I just used a spring loaded gun from the Depot. I believe it was 3/8" or 5/16" staples. I just had to push really tight against the plastic and it went right in. The only parts that were a little tough was where the cover was folded over 3 or more times. Otherwise I think you can make the standard staple gun work. Just gotta hold it completely straight and push really hard against the plastic...
I bought 1/4" staples for mine initially and after going through every curse word 3-4 times I went and bought some 3/8" staples and it worked much better. I set the seat on my small wooden coffee table so I could lean on the stapler really hard and drive the staples in. Some I had to tap flush with a small hammer. I imagine the new design staple guns with the trigger mounted the opposite direction would be better yet. 1/4" staples pulled out every time though. I did anchor it with 1/2" staples in the well padded part in the middle and some places where the material was bunched up (like the corners of the front and back of the seat).
Just finished my XXX seat cover and had the same provblem. Went to Home Depot and boutht a Powershot stapler. This one is unique in that the handle squeezes is reversed from most others line Arrow, Slimline... This means that as your hand pushes down it puts downward pressure on the staple. Most staplers will rock backwards as the staple is injected. :)
The powershot worked well but still required some staples be hammered down. Used 3/8 staples. Good luck. :D
Same deal: Powershot w/ 1/4" staples and tapping w/ hammer. I made my own seat cover from some twice-as-thick (at least!) automotive material that a friend gave me. It took a lot of patience and some careful work with a heat gun to stretch and shape it, but it looks perfect. For the cost of a new cover, it was worth it. It should be far more durable and it has a texture somewhere between "gripper" and "slipper".
Just one caution: Before you really staple 'er tight, fit it to the bike. Despite a YZ seat w/ a Clarke YZ tank, the front of the seat still was still forced up by the tank enough to induce a wrinkle in my cover. I had to redo it "extra tight" to eliminate this.
20 bucks at the local upholstery shop got mine done, and I didn't have to curse my whole family either when the staples wouldn't go.
  • Similar Content
    • By Zack Ailing
      hey guys just picked up a new project bike. Its a 2008 Yz450f with a big bore kit and a stroker crank. The total cc of the engine is now 499. It runs on race gas and will be an absolute monster when shes ready to rip. I will continue to make more videos on the bike so stay tuned Link to the video:
    • By High On Octane
      2005 YZ450F, Athena Big Bore, Power Bomb, Q4.
      Ok.  Last fall after a decently hot day at the track, I noticed coolant leaking from the weep hole on my water pump after pulling into the pits.  Ordered an Athena re-seal kit, put it all back together and didn't really get a chance to ride it.  3 weeks ago, went out to the track, and after about 20 laps, it started leaking again.  Kept filling it with water to get thru the day, never ran anywhere close to dry or empty, jut a cup or 2 low.  Ordered a Hot Rods re-seal kit with bearing and also ordered a new w/p shaft.  Did it all again and got it back together, ran it, and as soon as it got to temp, it was leaking out of the weep hole again.
      So, what the heck am I missing?  I'm totally stumped on this one.  Is something wrong with my case cover?  Do I need to replace the w/p itself?  I'm feeling like I should've just ponied up for the Boysen in the first place, and now it's biting me in the butt.  Any help or suggestions is greatly appreciated.  Thanks!
    • By Awheeler25u
      Alright guys, my 04 YZ450f runs fine minus some slight backfires when decelerating (need to adjust fuel screw). The other day when I was done checking my valve clearances I changed the oil and filter and put the bike back on the stand, kicked it a few times without the ignition coil in to get some oil flowing got off and noticed a little drip spot on the ground, it was no bigger than a dime so I thought nothing of it. Started the bike with no issues took it for a quick 10-15 min ride, came back to the garage to find out my whole case was soaked with oil and it started pooling in the low spots on the clutch basket side. I cleaned all the oil off and took it out again for 5 mins to try and see where it was coming from, here are my three possible places but nothing directly leads me to believe it’s any of the three either.
      1. Decompression plug area
      2.  Valve cover gasket leak (not really sure because the amount of oil leaking Looks to be a large amount
      3. Oil tank (bad weld or cracked weld somewhere
      what are you guys thinking?
    • By bofar
      Hey guys. I could really use your help diagnosing an issue that came up riding today. Bike is a 2013 YZ450F. Well maintained and haven't had any issues until now. Both the oil and coolant are new and levels are to spec.
      After riding for about an hour in the sand dunes, I noticed a grinding going on on the right side of the bottom end (from what I could tell). When I looked to see what was going on my kickstarter was vibrating and grinding really loud. This was a different sound than if you engaged the kickstarter while running. It sounded less "clanky" and more "vibrating/grinding" if that makes sense. Grabbing the kickstarter and moving it didn't help the issue.
      When I noticed it, I shut the bike off and gave it a second. Being a few miles deep into the dunes, I had to get it out of there so I started it back up and it seemed fine- no grinding. I headed back to the car and after a few minutes, it came back so I shut it off again, started it back up and nothing. That process happened one or two more times before I made it back to the truck. Seemed to run fine otherwise.
      Once I got it back to the truck I started it up and tried to pay more attention to what was going on but it wasn't doing it. I did seem to have more of a metal on metal noise coming from the motor. I started and stopped the bike a few times and after the motor stopped there was a distinct metal clank/grinding noise that happened right after the motor shut of for maybe half a second. This doesn't happen every time.
      I tried doing some research and have seen things that make me think it could be the spring that connects to the kickstarter, or the kickstarter stopper plate- but really I have no idea.
      Seems strange that the issue is off and on.
      Thanks for the help!
    • By Goof331
      Does anyone know if there is any differences between the 2 radiators? Will the yz450fx radiator bolt on a yz450f? What I am wanting to do is wire up a fan to my 2016 yz450f. I know how I am going to do it I just don’t want to use a “universal” fan kit. What I would like to do is get a 450fx radiator and the direct bolt on Trail Tech fan for that radiator to have a good clean look.
