After Market Headlight
I busted up my stock headlight on my "S" and was trying to figure out which after market headlight will work with the stock speedo computer.
the UFO Oregon is a worthless bag of crap. Matter of fact, every single UFO part I have used on my DRZ Dark project has been a cheesy Acerbis knockoff at 3/4 the price and 1/4 the quality.
I am about to order the Acerbis DHH in black.
I know the stock speedo will fit behind it (though I have a trailtech now) and I have seen them in action. That combined with the driving lights I mounted on the front fender.......
most headlights will fit on without too much trouble..
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
