J-E High Compression piston UPDATE
J-E just finished making the prototypes for the 13.5 DRZ pistons, and they will be ready for purchase in two weeks.
weight: 92mm 290gms
price: $154 (from JE, probably cheaper from distributor)
no part # yet. Here's their page for other pistons offered for DRZ... Andrew
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
