Vector Intall and some other goodies
Alright guys, I got some parts in and was got them mounted up. My bike is a bit more dirt and street ready. I got rid of my ugly front and rear flashers. I put the Zeta handguard flashers on, and some small smoked out ones on the rear that I got a cycle gear.
I added some Zeta shorty levers.
Added a Vector computer so I have engine temp and speedo with both sets of wheels. I used the back side of my battery box that I had to cut so I could fit the bigger battery in and used it to mount the Vector and the indicator lights. I had to bolt the speedo cable to the left side lower fork guard. It was too far away to pickup the magnet with it screwed to the caliper.
Add fat pegs and a longer gear shift. Also added some Unibiker rad guards. So I am much more street and dirt ready
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
