pics of my kdx200 blown engine
ok. so i get my bike home
im all excited, i mean this thing is mint, it is very clean. i got it for 270 bucks
it has procircuit pipe- silencer
tech care suspension
sun star sprockets
new brake pads
new maxxis tire
and racing number plate
its very nice
so i cleaned it all up removed the plastic
the engine was seized
1st i removed the ignition cover, took off the fly wheel. it was perfect
2nd i took off the kick starter, the clutch cover, the clutch and that was all perfect
.... i was hoping to find some easy problem:foul:
then i took off my head, and top end.... which came right off, so the piston was not seized
that scard me!!!
so now i thought it was the crank, i took my piston off and there was a bunch of metle shavings in the crank case, come to find out
the reason my engine siezed was my left hand power valve melted and put shavings in my crank case and blew my main bearings, and maybe my crank, im hoping not
i need alot of parts
its gunna definetly lighten the wallet
ill put pics of the brocken power valve later
Sorry to hear that. Unfortunately, that's not an uncommon occurance for a KDX that wasn't jetted correctly and never had the power valve cleaned. If the stock too-rich jetting is left in, the power valve will becaome so gunked up with carbon that the drum valves will seize, stripping the gears from the actuator rod and sometimes even breaking the valve, as happened with yours.
what should i change the jetting to?
it has a procircuit platinum and procitcuit spark arester??
do i need to change the pilot, main, and needle???
i may port and polish
i am putting in a hot rod crank also
Everything you could ever want to know about the KDX is HERE.
that was a steal
that was a steal
Thinking the same thing. Blown engine and all!! :worthy::banana:
Working on them is half the fun.
exactly lol, but the money spending is not haha
point taken. I like putting the parts in, yes. I do not like buying the parts so much...
Shop around and you can get good deals on everything you need. I rebuilt my crankshaft with new connecting rod kit and main bearings / seals for about 180 including labor. Splitting cases was not too bad, did it myself. New bearings through the tranny, PRO-X piston and rings, and she's back on the trails.
Good looking bike! Every time I go out on my 89 I fall in love with it all over again. Excellent woods bike. You got a good buy. Even after the rebuild you'll come out in good shape.
J.
try ebay or try buying a whole new engine off ebay you could get a factory engine fully rebuilt for like $400 all together it would cost you $650 so u still got a great deal and you have a new bike thats race worthy.
Say what? Show me a factory rebuilt engine for $400. Maybe a used one. Then you get it home and find out it needs rebuilt, so there's another 400.....
best work with what you have. Looks clean and in decent shape. Rebuild will be cheaper than buying new/used.
i would much rather rebuild my own for cheaper. i dont like taking the easy way out. that's no fun...
