Electric Starter
My electric starter was just clicking and wasnt turning the motor over so i replaced the brushes thinking that would fix it. Also the battery is new. Today i found out that wasnt the problem after the new brushes we installed. Last winter I got a stock 450r piston installed so did this put to much stress on the starter and cause it to go bad?
R and X pistons are exactly the same so that's not your problem. Might check your decomp clearance.
