shifter leak??
i have drz400sm and so after riding one day i noticed a significant amount of oil coming from the shifter (i think), so i figured the seal went bad. so now i have been trying to get the seal out, but cant (i got the c-clip off then thats it). i am now trying to take the clutch out so i can just pull the shifter shaft out, then get the seal out (is that possible?). but i now cant figure out how to take the clutch basket out, i got the nut off but it doesnt pull out all the way!!! also if i do pull the clutch basket out, will i need a new seal for that to? any info would be great thanks.
It's more likely that the oil is coming from the countershaft seal behind the front sprocket.
anybody got anything on the clutch basket part (its stuck). do i take anything else off after i get that nut off? i mean the basket slides on the shaft but stops at a certain point!!
am i missing something? i still cant get it off. it slides on the shaft but stops like the basket is either hitting the engine case itself or something is holding it on at the center of the basket. anybody got ideas????????
i have the right side engine case cover removed (held on by 8mm bolts). not sure what a clutch derby is?
oh i jus missed eddie's post sorry. im going to do that and see what happens
thanks
i hope its not a cracked case but i will look after i get all the oil cleaned off thanks
