200xcw: Poor idle at high altitude. Do I need smaller or bigger Pilot Jet?
I got poor idle at high altitude. Do I need a bigger or smaller Pilot Jet??? Bike runs great otherwise. It's a Rekluse fitted bike so I need to raise the idle. It's always fine at home 1.5K elev. but when I take it above 5K elevation i have to turn the idle screw all the way in just to get it barely to idle
current settings (factory recommended for elevation and temp):
air screw: 2 out
PJ: 40
needle: NOZI
clip: 2 from top
MJ: 155
Carb: Keihin PKW 36S AG
thanks for any input
Marty
does it get better if you open the air screw?
No, it makes little difference
^^^ I rechecked it, I seem to get "best" idle at 1.5 out. That's with the idle screw all the way in
bump...
when you open it past 1.5 turns does the idle go up?
no, it's pretty much the same
what about if you turn it in?
the idle will become unsteady and it will die
Any suggestion on pilot jet? Up or down?
had a compession gauge in it lately?
the air screw suggest the pilot jet is correct.
you lose compression at altitude.
will check compression. bike runs good but it does have close to 100 hours on top end
compression good. Went down to 38 on pilot. Took it to 8k elevation. Problem solved.
should have been able to open the air screw past 1.5 turns and achieve the same thing.
I agree. that's why this whole thing is so perplexing. Anyway, I'm happy now:ride:
Thanks for your input Eddie!
