First Ride 09 Te510
So i went camping this weekend to try out the new bike. It was very hot 105f but i sucked it, up and went on a 55 mile ride. Over all im very satisfied with the bike. It didn't overheat much, There was a little bit of fluid in the reservoir but not much. My biggest complaint was the handlebar shake. going fast either dirt or pavement the handlebars move alot. It gets kinda scary. Has anyone experienced this? In know there is the steering stabilizers but the cost is to high.
Could it be the front tire needs balancing? Or triple clamp adjustments?
I can only talk from an experience i had last year. I rode an 08 TE 450 and once the rear shock got hot it would lose alot of it's rebound damping. After hitting an unseen rock in the grass at speed it kicked so hard it threw me straight of at about 70 km/h. Also the forks sit too high up in the stroke which is sort of like trying to hold on to something with only your finger tips instead of your hand if you know what i mean and in turn tend to get a shimmy up even when doing 60km/h or so on asphalt. Very unnerving feeling. Apparently the problem is that there is a big rubber o-ring around the piston in the shock and when it gets hot you get oil blow by therefore reducing the rebound damping and transferring a sometimes very big kick through the bike.
I have just bought an 09 TE 450 in which apparently they did some revisions in the valving of shock but still had the same basic piston problem. I originally was a little bit reluctant to buy the 09 in case it did the same thing as the 08 even though i've been on Huskys for years, (2strokes). I sent the suspension to a guy here in Oz who claimed to able to fix the problem to weave his magic. I got the suspension back last friday and put it back in. MAN this is the most beautiful bike i have ever ridden. Better than the ohlins equipt bikes that i have test ridden in the past. It is like it's on rails and even turns easier than the 02 WR 360 i just got off which was a fair bit lighter you can just hit anything at almost any angle and the bike just goes straight it's amazing. The bike has still only done 80 km and the suspension already feels this good can't wait for it to bed in properly. I have also ordered a scotts steering damper from the states but if i rode the bike before i ordered it i probably wouldn't have. It will obviously make the bike even better but now i don't see it as a necessity like i did with the unmodified 08 it's more a luxury.
What he did was put a steel sealing ring on the shock piston, did a slight re-valve of the shock and forks and set the forks up so they sit between 5 and 10 mm lower in the stroke. This is what he told me he did anyway and some suspension guy on here might say all the above is a load of crap but all i can say is whatever he did i haven't enjoyed riding a bike so much in years and i loved riding before hand. I was also told by another suspension guy who is supposed to be the best in Oz that the shock piston is the problem also but he replaces the standard one with an ohlins piston. The guy who did mine said the piston is every bit as good as an ohlins it just needs the modification done to stop the oil blow by when hot and from how it feels he is on the money. These bikes are just magic when set up so ask some questions and do a bit of research and see if anyone in your area knows how to do the modification it's well worth it.
Also my forks are set up on the second ring from the top just so you know
Thanks for the reply, Yea the bike's power feels amazing i cant wait to get the suspension done. its just a pricey thing to do. im only 150lb's so im a little light for the bike as well.
Slightly off topic I'm also very happy with my 09 450, it pulls hard off idle through the mid range but falls flat up top, will taking out the exhaust bung liven up the top end?
jrmobb how,s your huskys top end does it turn good going up last chance cyn how s the efi going up hills or down vs the 530 ktm
Make sure your rear suspension sack adjustment is setup - too little sack decreases effective rake in the front end.
The bike pulls fine up top, turns fine for me. Its takes a little getting used to the efi going real slow. If u stall it going slow it takes a little to get started like the efi is confused. I just learned to use the clutch more when in doubt on the real slow finger trails.
I went from the very top peak in last chance its like 4800ft to Garlock road like 2k feet in a short time down a very steep hills. Bike felt the same at the top and the bottom
I have a 15t front sprocket
My buddy loved his 530, once he put in the Jd Jet kit he said it came alive. had no problems even up at 5k feet. He is allot better rider than me so he was flying down those hills.
myself and my son are on the fence about buying the 510 or 530 like the efi but not sure if its maped right . highspeed shake parts for the husky the ktm no rear linkage they leak oil an over heat .husky 8000otd ktm 8500otd with 1400 in hard parts
Well this is the wrong thread for those questions but They are both great bikes. You will get more compliments on the husky since there not as popular. The Efi works great and you can search and find most people love it. efi has been around for several years on street bikes so its not a new concept. You better hurry if u want a husky for 8k otd since the huskys for hero's deal end's tomorrow and u have to find a dealer that has one in stock, you cant order it and still get the deal. 8500otd will be very very hard to find for a ktm 530 but who knows you may find one. Im the only one ive heard about having shaking ill will do some adjustments im sure i will fix it. Ktm no linkage is a down side but it doesn't seem to affect ktm's multiple victory's in races.
Either way u will be happy
chris at to yhamha ktm gave 8500 otd with 5.9 four 48 indo husky 8000 otd 4.99 for 48 add 500 for the ex warrenty by the way great fix on the battery hold down
I'm about the same weight as you. We don't make the forks sit down in the stroke enough. Someone who is about 20 kg heavier wouldn't get the front end shake i would say
Did the shake happen at higher speed on smooth terrain? Maybe it's just your wheels aren't balanced. Nearly all dirtbike wheels are not balanced because of the slower speeds.
  • Similar Content
    • By MotoXRacer_19
      Does anyone know how to, or if you can, change your AMA number? The race number, not the full thing.
    • By Mike Michel's
       Would anybody know how many watts my 99 TE 410 stator
    • By KX290F Pilot
    • By Bryan Bosch
      Rockstar Energy Husqvarna Factory Rider Starts his Quest to Defend Cross-Country Rallies World Championship
      March 15, 2018 – (Motor Sports Newswire) – Rockstar Energy Husqvarna Factory Racing’s Pablo Quintanilla will re-start his 2018 international rally racing campaign on March 24 to 29 at the Abu Dhabi Desert Challenge in the United Arab Emirates. Working hard towards returning to full competitive fitness following a foot injury sustained during the closing stages of the Dakar Rally, Pablo’s teammate Andrew Short is expected to join the Rockstar Energy Husqvarna Factory Racing squad at the 2018 Merzouga Rally in mid-April.
      With the Abu Dhabi Desert Challenge playing host to the opening round of the 2018 FIM Cross-Country Rallies World Championship, the event in the UAE will see Pablo Quintanilla begin the defence of his FIM Cross-Country World Championship title. Securing eighth overall at the 2018 Dakar Rally in January, the Chilean rally star is already looking forward to a solid return to racing aboard his FR 450 Rally machine.
      Successfully wrapping up his debut participation at the prestigious Dakar Rally with a top 20 result, Andrew Short has been recuperating from a fractured tibia and fibula on his lower right leg. Resuming his training sessions in the middle of March, the American has his eyes set on making a return to racing at the Merzouga Rally on April 15/20, in the dunes of Morocco.
      Celebrating its 28th edition in 2018, the Abu Dhabi Desert Challenge is a six-stage-long rally taking place in the southern part of the United Arab Emirates. Kicking off with the traditional Super Special Stage on Saturday, March 24, the event will continue with five more days of racing in the Liwa Desert before competitors reach the finish line inside the Yas Marina circuit on March 29, 2018.
      Pablo Quintanilla: “Abu Dhabi will be our first race after the Dakar and I’m really looking forward to it. It’d be good to start the season carrying the #1 plate on my Husqvarna as the reigning champion. With it being the first race for the new season, it is important for everybody. My goal is to get a good race pace from the beginning in order to be inside the group of leading riders. The season will be long and my plan is to continue improving my pace as the racing goes on. I want to get back my racing speed and also remain strong throughout the event in Abu Dhabi. Taking place in deep sandy dunes, the Desert Challenge is always a tough event and it is also highly probable that we will have to race in high temperatures. It’s going to be a challenge but I’m looking forward to it.”
      Husqvarna Motorcycles. Tradition on two wheels since 1903.
      Husqvarna Motorcycles are widely known and respected in the off-road world for a heritage of competition and numerous motocross and enduro world championships. Originally founded in Sweden in 1903, Husqvarna Motorcycles have been designed and manufactured in Mattighofen, Austria since 2013.
      Rockstar Energy Drink
      Rockstar Energy Drink is designed for those who lead active lifestyles – from Athletes to Rockstars. Available in over 20 flavors at convenience and grocery outlets in over 30 countries, Rockstar supports the Rockstar lifestyle across the globe through Action Sports, Motor Sports, and Live Music. For more information visit:
      Source: Husqvarna Motorcycles GmbH
    • By DdrossyD
      Looking for some Wiring Harness, Connections and Installation assistance for installing a Tusk Universal Under the Fender LED Taillight with Brake Light on a Husqvarna 2017 TX300
      The UTFLight comes with a plastic connector that would work with the tusk enduro lighting kit which i'll be removing so that I can plug into the stock harness.
      I've been told the stock harness is the same as what would be included on the TE Model, minus the actual headlight/taillight being present; which is the case for the headlight wiring . it's all there ready to go.  For the taillight/brakelight however there is a bit more to be done.  There are NO wires running to the rear of the bike or within the SubFrame as some have noted
      I'll need to run to existing wires, and could use some guidance for which connectors are needed, if a supplementary harness is required(if so which one) and which wires to connect to on the existing harness.  There is very limited info in the manual (for either bike: TE/TX) or complete color harness diagram with info and connector information anywhere that I could find.
      I also picked up the Tusk Brake Switch Banjo bolt for the Brembo brakes (two wire, bullet connectors) - switch instructions.pdf
      On the Brake side under the front/bottom of gas tank near radiator there is an existing connector (I think for radiator fan) and from it, two unused wires, I would say for tapping into the existing harness.  1 Solid Brown, 1 Yellow/Red -
      Shifter side, near the bottom rear of tank I found taped up cylinder style connector (Someone can enlighten me) i think switch wires ? maybe some terminator,  each with the same color wire in as out.  One is Gray/Black and the other White/Black
      Under the cdi box is a three plug connector with two wires, 1 Brown and 1 White, third unused- i was hopeful this could be the tail light connector but am unsure
      Help on harness, connector names /types and setup is very much appreciated
