Getting a yz250
A guy wants to trade his 03 yz250 for my 03 yz450.
He says it has only 10-15 hours on top end, but you can never know before you open it.
Is it anything I should check on his bike before we do the trade?
I was planning to take a compression tester with me.
How much compression should a relative fresh 250 have?
Check the sprockets for wear, see if the oil is black which would mean it's dirty or if it is golden which would mean it is clean, check the air filter and air boot to make sure there is no grit, check the wheels for any bearing movement, ask what mix he ran, how often oil was changed, how often air filter was cleaned.
it should have around 150-200 but i would also take a spark tester to check spark to make sure the ignition isnt fixing to go out on it
Got it now, was in way better shape than my old 450.
Good choice, 2 stroke FTW! :worthy:
As I recall, the 2003 YZ250 was an excellent machine, congrats!:worthy:
  • Similar Content
    • By Rick Mcqueen Art
      A tiny clear rubber tube on bottom of carb.  On bottom sort of on side, by floats, the other end just hanging down.  Was it always like this? Or does the other end go somewhere?  Today after multiple trys with kick, choke on/off ,,,fuel keeps pouring out the tube.  This bike has always been hard to start.   Thanx  guys!
    • By Brock granberg
      I just did my valve adjustments and put my YZ250f back together as far as the valves, shims buckets and cam covers on but I need adhesive for the plastic valve/cam cover and I am stumped as far as what to use and where to get it or even what to call it! Need to get some soon im in need of a ride!
    • By ThatE30GUY
      Hey guys, I bought this YZ85 and came to realise the clutch wasnt working, so I drained the oil (Jet black) and pulled the plates out and cleaned them. I assumed finding a torque wrench would be easier than it has been. Does anyone know how to torque the clutch springs to spec without a wrench? Any insight helps.
