Converted from air box to K&N cone, now power breaks up at high RPM.
I've restored a 1970 Yamaha AT1 that serves as my around town scooter and occasional trail bike. One part that I could never find was a new air filter to fit in the stock air box, so after a year of riding around with a man-made hack job air filter in the box, I found a K&N cone that fit perfectly in the space once occupied by the air box. The bike starts and runs fine, that is until I have it at full throttle approaching the power band which is about 6,000 RPM, where it completely falls on it's face, any ideas on how I can solve this?
I would guess that you are getting more air flow with the K&N. I would try putting in a bigger main jet and see if it improves.
10yeareer is probably right that it's getting more airflow with the K&N. If you don't have any larger size main jets to work with you could try restricting the filter by covering say half of its filtering surface with tape. If the problem gets better or goes away then you've proved the theory.
:worthy: get rid of the K&N
prolly be better off with some coffee filters:smirk:
  • Similar Content
    • By Rick Mcqueen Art
      A tiny clear rubber tube on bottom of carb.  On bottom sort of on side, by floats, the other end just hanging down.  Was it always like this? Or does the other end go somewhere?  Today after multiple trys with kick, choke on/off ,,,fuel keeps pouring out the tube.  This bike has always been hard to start.   Thanx  guys!
    • By Brock granberg
      I just did my valve adjustments and put my YZ250f back together as far as the valves, shims buckets and cam covers on but I need adhesive for the plastic valve/cam cover and I am stumped as far as what to use and where to get it or even what to call it! Need to get some soon im in need of a ride!
    • By ThatE30GUY
      Hey guys, I bought this YZ85 and came to realise the clutch wasnt working, so I drained the oil (Jet black) and pulled the plates out and cleaned them. I assumed finding a torque wrench would be easier than it has been. Does anyone know how to torque the clutch springs to spec without a wrench? Any insight helps.
