2001 yz80 forks BROKE MY DAMPENING ROD
The girlfriend has a 2001 yz80 and when i went to replace the fork seal on the left side some clown had cross threaded the cap onto the dampening rod. I tried to remove the lock nut from the rod after removing the cap and the threads were all banged up an it snapped about 3/4 of an inch off the dampening rod. Can i replace the dampening rod myself? Where can i get a new cap and rod? And how much?
Thanks for the help
FYI i checked ebay and found no used forks or really anything for that matter.:worthy:
The cap you can get from us or from the dealer.
About $49.
Dealer may be less.
The rod cannot be had without getting the complete cartridge, that is for the 01. The 02 and up is a different story.
That said, most KYB rods that I have worked with can be welded and recut, unlike the SHOWA rods.
Judson, I replied to your e-mail. Let me know if you didn't get it.
Thanks for the help! If i get a set of 02 or newer forks will they fit inside my clamps and will the bolts line up correctly for the front brake?
Like I said in my e-mail, they're all the same.
