rubber bar-mount cones (07 kx250)
so, i got some new taller bars (flexx bars even, since I'm old and frail), and I got some pro-taper oversize barmounts that replace the stockers but still use the stock rubber cones. Unfortunately, every time the bike tips over, or hits a bigass boulder in the A-loop of a national enduro and doesn't tip over, the bars get severely tweaked. Not sure If I over-tightened the mounts or under-tightened them or what, but it happened about 4 times over the last 2 weeks, including 8 mins before the start of the last test at the rockpile national (montana) where the bike stood still while I took off the seat and pulled the filterskin, but then jumped over when i turned my back to pee. :worthy:
Lol, luckily i fixed it in time, but i'm wondering, how tight should those clamps be, and should i get new ones, or aluminum replacements or something?
I tighten mine very tight. I have had good luck and only bent one set of bars on the KX's. I have only used stock rubbers so I can't help on any thing else.
I never had a problem with either of my KX's doing that, but I think Dennis Kirk sells some aluminum inserts to replace the rubber cones.
Get a one-piece top mount. That'll fix 'er right up.
Your bars will be more prone to bending w/o those cones taking the hit. Usually a few strong whacks against one of the steering stops and I'm off and running.
I had the same problem on my '06. The bike could tip over and tweak the mounts. I even bent one of the OEM posts. About a year ago I got fed up and bought the ProTaper upper tripple clamps and it solved the problem. And they have different rubber densities for the vibration control. Not the cheapest solution but it cured my problem - I haven't had the bars move since.
Somehow the 2006 and 2007 KX250s' have single mounts, but they used to have a single top piece at least back until 1987, if not further.
I'll bet if you put them in there and tighten the bolts real good they'll fit lol. I do agree with the one piece top bar clamp and use them on mine.
The folks at applied claim those don't fit the kx. naturally, they want to sell me a new top triple clamp.
here is a pic of mine 05 KX450 top clamp (same cones as the 250 2T) nuts finger tight, prior to mounting n548652524_1736146_8688.jpg
I can't remember where I got them (possibly Pit Posse)but they were sold as the applied racing cr cones.
the theory is sound and it is the same reason skateboard no longer use rubber. It is actually the metal washer that bends, but each time you crash the rubber loses strength so it tweaks easier next time.
If you are not bending teh metal washer you need to learn how to crash harder :worthy:
Have you considered getting a 2005 KX250 one piece clamp? It may also be on another bike, such as the 2005 KX250F.
It would be silver instead of brown, however.
2005 is when they went from 90mm spacing to 98mm spacing.
gas 4 u. thanks for the link. I guess if motosport sez they fit and u say they fit, that's good enough for me. although their website was screwing with me so i had to call them, i got them ordered.
I think the taller bars i'm using may cause more tweakage than the stockers.
after one real good crash you can pretty much tweak the stockers with a good sneeze :worthy:. the Sanoprene ones are holding up great for me but I am also keeping the rubber side down so far
so how are the applied racing rubber cones holding up, are they fitting propperly, i called motosprt to day to order them and he said they wont fit the kxf, and he was trying to sell my eaton bar/combo kits and so on. i just want some good rubber mounts, i hate the stockers and dont really want solids.
I'd like to know as well. This problem is so annoying, even the littlest tip overs tweak the bars all over the place. I can't tighten them up anymore either. lol
I got mine from Langston racing i think they are made by Zeta...
ok, i called langston about 2-3 days ago and they were out of them till about 3-4 weeks till their next shipment came in. ill try again. thanks
i only have 30 or so hours since i got the ones mentioned above, and i'm not sure i've fallen over, but they seem to work great.
  • Similar Content
    • By Tedstrom
      Alright so I just rebuilt my 2012 kx250f complete rebuild. I put the motor back in the bike get everything hooked up and ready to go it takes a few kicks at first (obviously) but after it starts it sat and idled just fine for a while then it stalled out. Tried to start it again wouldn't start I took the spark plug out of it it looked good I was dark and wet. I cleaned it then put the spark plug back in it it took a few kicks but started right back up again then after a while it stalled out again and now I can't get it to start again!? Any help would be greatly appreciated thank you guys and girls for reading and hopefully for the help!!!
    • By luke8500
      Hi all,
      I have a 2004 Kawasaki kx250 that died suddenly on me the other day. all i can get it to do is backfire every once in awhile. Tested the resistance and everything of the magneto and stator with a multi-meter and all is good.  Coil is new oem Kawasaki the reeds are brand new vforce and the top end and carb have been completely rebuilt.  key on crank is intact and all the timing marks are lined up. I hooked a timing light to it and spun the motor over really fast and found that it is sparking way to late.  The service manual says that it is supposed to fire 14 degrees before TDC but it is sparking way after TDC.  Im thinking its a fried CDI box since its the only thing i wasnt able to check.  Any help would be appreciated
    • By luke8500
      Hi all,
      I have a 2004 kx 250 2 stroke and it wont start.  it only backfires.  I was out riding it one day and came up to a stop so the bike was just idling and it started to try and die so i revved it up a few times then let it die and now it wont start back up.  It only pops or backfires when you kick it.  Its getting good spark and i just put a brand new plug and coil in it. I took the reeds apart and they look like they're brand new.  It was running great before so i dont know what happened.  Im thinking it could be a fuel problem even tho the plug is a little wet if you take it out after a bunch of kicking.  Any help would be greatly appreciated
    • By Zach121
      Alright, found three bikes all located where i live in Texas. I know they're all very different, but if you could tell me what you think each bike is worth, and which one would be the best deal. Thanks.
      Notes: Both 2 strokes have new top ends. I think the front brake lever is broken on the kawasaki.
      KX250 2002 $800-$1000?
      YZ125 2000 $1250
      KTM 400SX 2002 $1200
    • By Ryan Turner
      So I'm at a bit of a cross roads, I currently own a 06 rm250 and I love it. I also have a 02 kx250 which I'm selling with intent to buy a newer two stroke. I can't afford a newer ktm and the older ones aren't that great and kawasaki never impressed me. so I'm stuck between 06 yz250 and 05 cr250. I've heard the yz and rm after 06 are almost the same bike just the Suzuki handles better and the Yamaha has better suspension. So I'm not sure if I wanna buy carbon copy of my bike with slight differences. That's why I'm interested in a cr250 I heard the 02+ models RC valves are shit garbage but was mostly fixed in the 05-07 models. I ride at a track and at some bogs down the road from me. So from people who have owned both, what would you recommend. I know the cr is known for a hard hitting power band which I enjoy since im an aggressive rider. Should i just see which deal comes my way first.
