Going back to knobs.
I gave the trials tire thing a fair shot and they do hook up very well but they
dont suit my riding style. My problems with them are:
-make the front end too light exiting corners
-slide out way too easy exiting turns
-almost impossible to correctly brake slide a turn with one
-cant undercut and brake pass in turns cause you have to be too ginger with the throttle exiting the turns.
-suck in grass fields
Pros are
-excellent climbing-
-excellent in rocks
-excellent climbing
-excellent in rocks
Mind you, I didnt get a good trials tire to test out, but the Hare Scrambles I run have flat turns, grass tracks, and the trails are so tight that you gotta pass when you can, not when conditions are perfect for a trials tire. I think with having the Tubliss system and knobbies at 5-6 psi, it will pretty much cure everything I was trying to fix with the trials and give back what I was giving up to run a trials tire.
