Mikuni hsr45 on Xr650L
Hi there I have a xr650l that I have built upt to a 706CC 12 to 1 compression a megacycle cam with a stock header with an E2 muffler. I am running on cali super unleaded. I am setting up a msd programable single cylinder igntion and would like the jetting to be a little closer so it can run smoother. I am familar with tuning a FCR but not a Micky. I have tuned it on a dyno jet 250i and got a baseline. the screw is 1 3/4 out a 30 pilot a y2 needle on the richest clip and a main jet of 145. if I do a full pull the airfuel ratio looks diecent except for a lean spot of 14 at 5500rpm and then tapers down to 12.6 at 8000rpm so the dynot chart says that I need a richer needle but when I am at 1/8th to 5/8 throttle at stable speed it is reading 10 on afr and stumbling bad. so when I do a roll on pull at wot it bypasses the bad area and pulls strong. the afr previously was almost 15 on the previous run and I changed the pilot from a 40 to a 30 and it helped the torque about 1.5ftlbs. should I keep leaning out the pilot or should I order up new needles I would like to figure out which direction to go before I order needles. tank you very much
doing wot rollons on a dyno is a main jet test for the most part.
you determine pilot jet selection by idle reaction to the fuel screw and the measured a/f ratio. needle is set up via steady throttle tests.
pilot circuit is for idle and just slightly off.you should not be tuning power or response with it.
throttle response is tuned with the accelerator pump.
does the idle react to the fuel currently? idle with the fuel screw full in?
your main jet sounds alittle big still.the a/f line will never be perfectly flat with a carb.its just how it works.
your steady throttle a/f is bad becuase you trying to tune response with the needle.you need to set it for clean steady throttle running. 13.0 - 14.0 afr.
this your dyno?
yes the idle will start to stall out when the screw is 3/4 out.
so the steady throttle 1/8 to 3/4 is all needle. Have you ever heard of the hsr harley mikuni having a hard time to tune. I dont want to be chasing this thing all over and it end up not working for my motor. Yes it's Dan Gurney's dyno I just run it. like i have set up a lot of fcr but no mikuni's, thanks for your time.
correct,you tune 1/8-3/4 steady throttle with the needle. 1/8-1/4 is the straight diameter and the rest is clip position and taper.
its no harder to tune than any other cabr but tuning info and parts i no where near what a fcr is.
i think its a touch big for that motor set up.
Change of plans now.
Sudco says that the needle that is in it is the leanest that carb will go. I guess I will throw the fcr 43 onto it. I was just leaning twards the mikuni because it flows better on the flow bench. sounds like I was walking into a road of issues if i kept using it. so good bye micky.
if you have the needle in the richest position you should try leaning it to see if it comes around.clip position has a drastic effect.
  • Similar Content
    • By Sammy_1101
      Hi Guys,
      So I recently bought a 1997 XR400. I've done some research into getting more power through some basic mods and rejetting the carbs. Though all of the ones I've found have been for post 98 XR400s so the stock carb set up is a lot different. Usually people are opening up the airbox, exhaust ect. ect. and Jetting their carbs up to 160/162 for mains around 60 ish (I think) for the pilot. However for the 97 model this is close to stock for the jets.
      So essentially what Im asking (Just to cut to the chase ) Has anyone got a 96/97 (maybe 98, not sure) XR400 and has done these similar mods, and what sort of jetting have to done as a result.
      Thanks in advanced, also its my first post so apologies if I havent done everything correctly.
    • By Jturn
      38MM Cast SmartCarb. Purchased a couple years ago for a yz250. Don't have the bike anymore, and it has been sitting around for about a year. Used, but in fine working condition. You can also purchase a different needle for different bikes, as well as rebuild kits from their website.
      Asking $250 shipped to continental United States. I can arrange other shipping options at the buyers expense.
    • By faizakhtar125
      Hey guys I just bought a bike last night. So the seller said the bike will turn on but then die. We didn't try it because it was really late at night and it was raining (seat was wet). But he said if you bump start it, it will turn on and ride. So what do you think the problem is? I just want to make sure it runs... I probably won't be able to bump start it till Saturday (rain)... It's a four stroke, and I know absolutely nothing about them. Thanks.
    • By knotduke08
      I know this topic has been discussed in the past, but I have not found any options available for the new 2018 bikes. I live and work for a new Beta Dealer (Auburn Extreme Powersports) in California, and we are having a difficult time mapping the RR-S bikes for full FMF exhausts. We have tried contacting Beta Support several times for this issue to no avail, and we typically are given the runaround when transferring to techs and secretaries. From what we can gather, the FMF flash is designed for the RR bikes, but not the street-legal counterparts. Every time we try to install the FMF map onto an RR-S errors occur, and the programmer screen goes virtually blank. We have heard through the grapevine that some are using the RR maps on the RR-S with success, but we have yet to try it, even on our own bikes for fear that it will permanently erase or damage the CDI. Any and all help or suggestions regarding this topic would surely be appreciated! Thanks, Ben.
