07 Ktm 450 Xcw Help!
What to do, What to do?
I have spent a fortune on this bike, Scotts stabilizer, FC suspention, rebuilt just 300 miles ago, fuel screw, boyson qs2, the list goes on and on! I spent $3,000.00 3-400 miles ago, this bike is dialed in for me, my wt and riding style, or lack of it.
I rode the Classic and took some mud on in a mud hole. I am told I need a NEW engine and it will run approx $2,500.00-$3,000.
Here is where I need some advise.
I am a public servant and don't have money to burn again.
I can part the suka out, I have never done this and it sounds like a lot of work. What could i get for a blown up bike?
Anyone know where to buy a complete new engine?
How about a used engine. Can a 525 fit in the 450 frame?
If i could break even, I would love to switch to a cheap 2t. No more $1,000.00 rebuilds.
I am old and slow and nerotic about maintanance, I just have no luck.
Any and all advise is apreciated.
A little more info.
Yes the bike runs, smokes alot.
I just did a complete top end rebuild at Masons and it was around 800.00.
They took the filters and screens and saw mud in there and in the carb.
I was told once the dirt circulated through the bottom it is very bad.
They are looking into the cost of a new engine and thought it might be $2,500.00-$3,000.00.
I do the minor stuff, but rebuilding a 4 stroke is out of my league.
The bike was running better than new. I stalled in a mud bog on Saturday. I did not think it was all that deep and I did not fall over. My feet did not even get wet, I have been in worse. My electric start had already shorted out and I stupidly kicked away in the puddle. I finally gave up,put a new fuse in and it fired right up with the e-start.
It rode fine until near the top of the ledges where it stalled and then I was hearing some top end clatter. Bike cooled down and ran fine back to camp.
I rarely rev this bike and change the oil and air filter every 10 hrs.
At camp I could not see the oil in the window, well very low and I had to tip the bike to see it.
I put in a whole liter.
When I started it it was now smoking worse than a rich 2t.
I assumed that the sight glass was smoked and I could not see oil now either.
The bike rode fine, although I did let Lafferty pass me as I did not want to push the smoking beast. I assumed extra oil would burn off and not damage anything if I kept the rpms down.
I made it to the first reset, 10 miles and the bike started running like it was not carborated right. I dropped the oil and the brand new liter was black and smelled burnt. The magnetic drain plug was covered in what looked like mud. I assumed it was metal clutch material, the magnetic nipple was not visible.
I gave up and got a ride back to camp.
I spent all my $ in the last rebuild and decided to keep the bike and sunk $3,000.00 in motor, carb, plastics, tires, chain, sprockets etc...
Masons did a great job, but I am busted and my wife will leave me if I spend that much a second time 300 miles later.
Thanks for the help.
I am uncertain how the mud got in as the air filter was clean and I stuck a paper towel past it an it was also clean.
If my crank case breather hose was rerouted into the air box, where whould mud get in.
I did kick it numerous times in the hole. could enough mud get sucked up the carb hose to do it.
They did find mud in the carb.
I think Mason's is giving me the worst case scenario as they have not taken it apart yet. They are a great shop, not cheap, (like all shops) but definately fair and only sell KTM, so the know these bikes better than most.
I love a good mystery, just not an expensive one.
Kevin I agee, I love mud and am the idiot who goes back and forth through the mud holes. My feet did not even get wet. I did kick it a hundred times before pulling it out and starting it.
I trust the shop and they may be more interested in top performance right now than I am interested incheap just riding.
It Pays to Play!
Ow, That's going to leave a mark!!!
Ride faster and you will get farther.
Wow I can't believe that nobody chimed in to help this guy. Outthumped, I hope everything worked out. I would check e-bay for used engines, or better yet find a friend who will help you rebuild the thing. It's not that hard if you take your time and have a good shop manual.
As his problem was 17 months ago, I assume he either got a new engine or sold the bike. He has only posted one post ( in November this year ) since his problem. In my opinion, there was something strange going on with his engine, and it would be interesting to hear how things went. ??
  • Similar Content
    • By Ponch
      I have a 2007 450 EXC that I recently installed a new clutch slave cylinder on. Per the 2007 KTM service manual it clearly states that the clutch needs to be filled with hydraulic oil, which I did (magura blood). That was yesterday. I went out to double check the level today and when I removed the cover, the rubber seal was all contorted and out of shape. I then looked at the cover and it's a Brembo clutch and says "DOT 4 brake fluid only".
      I flushed the line and the master cylinder about 7 times with DOT 4 brake fluid and there was no sign of the magura blood left in the system. My question is: other than the rubber boot on the master cylinder, what damage might have been done by putting in the hydraulic oil? It was in for about 24 hours.
      Thanks in advance for any advice!
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
