tripple clamps
I have been wondering the same thing as some companies list them as the same and others different.
Also will a lower 20mm clamp work ok with a standard top clamp?
Thanks
I have 09 clamps on my 06.
Same bearing dimensions. Using the 09 steering post too.
06 to 08 post and clamps are the same dimensions.
The clamps will fit, all the difference is that the 09s need alittle more clearance. I sent my 08 RG3s back and they just shaved alittle off the lower clamp for clearance. The 24mm offset will not set with a 23mm offset. You could probably make it fit but it would be to tight and bind.
Here is a couple pics of my lower clamp, you can see how there is a bevel in it. All you would have to do is file the 08s down alittle and they should fit.
