what is a quite insert
I have a Yoshimura TRC with a 96db insert.
Just out of interest, what is it about an insert that makes the db level less ?
Is it the length of the insert, the diameter of the insert or something else ?
:lol: I don't know how yours looks,but on my 2brothers,it's exit hole is smaller and tapered.:lol: :lol: :worthy:
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
