Unconfirmed verdict on Steering Dampeners
I'm told this is the best place to get any negative feed back on steering dampeners. Those who have them swear they would never ride with out one again. This seem to be a small minority of the riders out there though. If they are so wonderful why don't everyone use one?
I ask this because in the last 2 race seasons since my son began racing motocross I have looked for the dampeners on motocross bikes. I bet I have checked out over 1000 bikes in the last 2 years and I have not found a single bike with one on. So what's up? Are they just a cross country or enduro thing? If they work/help why don't I see them on motocross bikes?
They are expensive.
If you get the chassis set up correctly, you can get by without a damper.
Too many people use one to try and correct a bad chassis set up.
They are great to add to a bike that is setup correctly. They can save your butt in the nasty suff and high speed stuff.
Icing on the cake.
I love dampeners!!!!! I never rode with one until about a year ago. They are nice but the money is a driving factor as with most things. It is total rider preference. I would have your son ride with the dampener on full hard and then on full soft. Then any level rider can usually tell the difference. If he likes the effects they have they keep adjusting it to where he likes it. In sand i almost need to have one. Hard packed is easier for me so it is not really needed, but i have hit rocks before in hard packed and been saved by my dampener.:worthy:
Not to be a nerd, but the term is actually 'damper', not 'dampener'.
I don't know if a damper would mess up ones scrubbing on a mx bike. I find them handy for high speed desert racing, but useless for enduro and normal off-road riding. some bikes seem to need them more than others. Some people seem to need them more than others. I don't see alot of them being used by WEC and ISDE pro-level riders. I see lots of american desert and worcs and enduro guys using them. I'm guessing they don't pay for them. I'd use one on every bike if I were paid to do so, and I'd claim they were indispensable.
Elbows up or damper, it depends on how fast you can learn the habit.
all new hondas have them!
I always run a GPR dampner on my bike. However on MX track it is set to lowest postion. I think a dampner shines in rough stuff when you are tired say two hours into a cross country race. I have had a root or rut grab my bars and nearly pul them out of my hand. I thank the dampner for saving me again. Also you can have your bike setup for tight woods and then rely on the dampner to keep head shake at bay on topped out sections. Also I think some of the factory teams in MX run a small shock absorber type dampner on thier bikes instead of a top of the bars type adjustable setup.
Well...understand that there are different ways to damper the hinge between the front and back.
In other words, an Ohlins or Scott will behave differently than a stock Honda damper will....so input, feedback and advice will vary.
negative stuff about steering dampers ... OK my 4c worth
im not 100% convinced the non honda types are a good thing on a well setup bike, what I noticed below 100km/hr in technical stuff is
instead of the bike stepping out to say the right which is a great thing for clearing a nasty section and crossing ruts to get a better line it leans over to the left. not a bad thing I suppose.. just different.
landing a jump front wheel first and having the front wheel try to deflect while the back wheel is still in the air is a very scary thing since the back gets thrown to the side. granted I had the HS adjuster too stiff in this instance but it didn't help at all in other slow speed situations if it was set softer. ie to be effectively useful below 100 it has to be set too stiff to be safe.
messing around with it a lot and playing with sweep control I also found the bike more tiring to ride in slow terrain if i set it stiff enough to actually work in the slow terrain.
for fast stuff 100 - 180 km/hr with the power on and the back wheel firmly planted in the dirt where the front skims along and tries to deflect it is simply sensational. Im not taking it off but have found its limitations and don't expect as much from it anymore.
I think the honda ones are better for slow technical stuff and MX.
  • Similar Content
    • By Chris Edwards
      Hey guys, I'm wondering what suspension settings you all are running front and rear?  I have a 2017 crf 250r I'm a 210lb newer rider, my settings are currently set at,
      rear suspension low speed  at 12 clicks
      rear suspension high speed 2 turns
       rebound is 12 clicks.
      Left front fork inner chamber 150psi, outer  chamber 10psi, balance pressure 150psi
      Right front fork compression position 7 clicks, rebound 29 clicks
      Sag is 4"
      Thanks guys
    • By Stillwell Performance
      One of the most common calls we get here at the shop is “how do you recommend I go about tuning my suspension?” Good question! The second most common call is “I started turning clickers on the front/back/bottom/top etc. and now I don’t know what I did, help!” The amount of improvement you can gain from proper suspension setup is significant, if you go about it in the right way.
      Look at it this way: if you are 6ft. tall and get in your truck after your 5 ft. 3in. wife just drove it, the first thing you are going to do is adjust the seat/steering wheel, etc. for your size. The same thing goes for your bike’s suspension-last week we had (3) 2010 bikes in the shop for revalves at the same time. Identical models, one guy was a 150lbs. pro racing MX, the next guy was a “B” level GNCC racer and weighed 220, and the third guy was a 180lbs. trail rider. Same bike, three totally different setups!
      So with that in mind, here is where to start:
      • Grab your owners manual, a computer, clipboard and a scale. You cannot effectively start tuning until you determine if the correct springs (fork and shock) are on the bike for your weight. Put down the double cheeseburger, hop on the scale, and get your weight in street clothes. Add in for your gear, which typically runs between 20-30lbs. You can easily check recommended spring rates by visiting www.racetech.com under their spring rate calculator. Look in your manual (or ask your tuner) and see what rates are on the bike.
      • If you need to change spring rates-do it first. Trust me on this, trying to tune suspension with the wrong rates is not only frustrating, but you will be short changing yourself on the results. On most bikes the shock spring is easily changed, fork springs can be a bit more difficult-get qualified help if you need it.
      • Even if you are familiar with what “clickers” are, take a moment and read your manual. Determine what style of forks you have (closed cartridge or open cartridge), where the compression and rebound clickers are, and check to see if your shock has both a high speed and low speed compression adjustment.
      • Grab the right tools to adjust, load up and go find a typical piece of terrain to test on. By typical I mean your MX track, hare scrambles course or favorite singletrack. You don’t need to ride a 30 mile loop in order to adjust your bike, rather focus on finding a section of track/trail that has all the different types of jumps/bumps/whoops you encounter.
      • OK here is where I will preach a bit-everybody has a buddy or two that claims to “know suspension” and setup. This is YOUR bike, and unless you plan on dragging him around on the back of the seat the end result of your tuning should be focused on what feels good to YOU. Trust the feedback the bike gives you…..
      • SET YOUR RIDER SAG!!!!!!! This is critical to tuning properly. Again, look in your manual or ask your tuning dude.
      • If you do not have an idea of where to set your clickers, put them in the middle of their adjustment range. This is your baseline setting.
      • Gear up and get warmed up. It is important to be loosened up on the bike BEFORE you start tuning, or you run the chance of mis-diagnosing how the bike is feeling (I never start testing until I have at least 15-20 minutes of warmup time on the bike-I always ride stiff initially and sometimes do not get into a groove until then). Some guys can just jump on and pin the damn thing right from the truck. You know who you are, Wattsy……
      • Remember, this is a tuning session not the MXoN. Use you head and ride at a pace UNDER you max speed-there will be plenty of time to “fang it” once you have zeroed in on some good settings.
      • OK-ride and get a good feel for the bike with the clickers in the middle of their range. Now it’s time to really find out what “too soft” and “too hard” means.
      • Take your clickers and turn them all the way out, full soft. Go ride the bike, but take it easy-it will feel ALOT different. Then come back in and turn everything all the way stiff-go ride again, being careful as this will feel totally different again. For guys that have tuned a bit, these two steps might seem pretty basic, but you will be amazed at the difference in how the bike feels. This is especially helpful for guys who are just starting out.
      • Set everything back to baseline. FROM THIS POINT ON YOU WILL ONLY MAKE ONE ADJUSTMENT AT A TIME!!!!!!
      • So now you will want to determine your tuning range. The tuning range is what settings you will use to adjust for different conditions. For example, If you are an MX racer as well as an occasional singletrack rider you will want to use different settings for those conditions.
      • Fork compression is a good place to start. Ride your test section at baseline, then go about 3 clicks softer. The question to ask yourself after each adjustment is: Does it feel BETTER, WORSE, or THE SAME????
      • There are no right and wrong answers, only what you feel. So let's assume that the 3 clicks softer felt better-go 3 more clicks softer each time until it does not feel as good. You have just found the soft end of your fork compression tuning range. Now return to baseline and do the same thing, only this time go stiffer. After you have found the best compression setting, work on rebound. Remember, one adjustment at a time ONLY or you can become confused!!! Do the same testing with your shock. Once you have both comp and rebound individually adjusted, you can fine tune them to work together-just make one adjustment at a time!
      • As a final test, when you have what you would consider your best setup, write it down, then go back and compare that to your initial baseline, riding both setups back to back. Might surprise you…….
      I could go into some advanced tuning topics about the interrelation of compression/rebound, high and low speed comp, tuning for extremes, etc. but we will save that for another newsletter. Take your time, tune by how your bike feels to you and have fun. You will be surprised by how much better you will ride with well adjusted suspension.
      You can learn more at www.stillwellperformance.com
      KEEP IT PINNED!!!!
      Alan Stillwell
    • By Jo_nathan
      Selling the showa A kit off of my yz250. It comes with a set of like new x trig adjustable triple clamps. Have 4 rides on rebuild and overall in great shape. Few dings, no dents or leaks. Setup for a 165lb a rider. Work absolutely awesome! I got hurt and cant ride for a year so I'm selling off some of my parts.
    • By Kim Franz
      lookin to upgrade my suspension on my 06 cr250, curious whats possible with some work.
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
