YZ250 1st Gear Problem
Hey guys, I recently rebuilt a 97 yz250 top to bottom. I rode it for some hours last year and it ran great. Now this summer i brought it out and the first thing i notice is when im in first gear the bike jolts as if its missing a couple teeth. But all other gears work fine and everything shifts great.
So I tore it back apart to find no apparent failures in the tranny.
I have all the diagrams and have gone over several times to make sure nothing is missing and its all put together properly.
Some insight - this bike previously had tranny problems and i replaced a couple gears and a shift drum.
So my questions is even if i did put the tranny together wrong why did it work for sometime and then start having this problem? To me it would make more sense if something where to come loose to cause this problem.
Also now that i have the case split when i spin the tranny by hand at some points the tranny binds. I've heard ppl talk about bent shafts causing this problem.
Give me your thoughts I don't want to put this back together without finding out for sure what the problem is.
Check the engagement dogs on first gear. See if any of them are rounded off or broken/chipped.
I checked and all gears are in good shape, even if it was slightly worn i couldn't see it causing a problem that extreme. As i was taking it apart i was expecting a total mess for the first gears.
I'm not talking about the teeth on the gears. Look on the back side of the gear where it engages the gear next to it on the same shaft. There are protrusions refered to as "dogs" that fit into the gear directly adjacent to it on the same shaft. If these are worn out then it can jump in and out of gear giving you that lurching of the bike.
Any update, 2nd gear is doing a similar thing on my 125
  • Similar Content
    • By faizakhtar125
      Hey guys I just bought a bike last night. So the seller said the bike will turn on but then die. We didn't try it because it was really late at night and it was raining (seat was wet). But he said if you bump start it, it will turn on and ride. So what do you think the problem is? I just want to make sure it runs... I probably won't be able to bump start it till Saturday (rain)... It's a four stroke, and I know absolutely nothing about them. Thanks.
    • By neonmarine
      Hey guys,
      I've used this forum as a "guest" for awhile now and I thought I'd share my build now that it's all coming together.  The primary purpose of this project is to help me train for roadracing my 2009 R1 at lower speeds as well as giving me a cheap alternative to racing the big bike.
      Here's what she looked like when I picked it up from a local shop.  Paid $800 cash for the bike as you see it with 17' rims, FMF pipe, EBC 250mm front rotor and clip on handle bars.
      Fits PERFECT!
      Shake down run at the Herrin Compound last summer:
      As she sits today:
    • By 125 yamaha guy
      i bought my yz125 from a dealer and they said that the clutch was broken so i bought it and it worked fine it would run move and everything and then it started to act up and now only first gear works barely though. when you put it in first it acts like its bogging down but its not and when you go into gears 2-5 it wont move i dont know whats wrong with it im assuming the clutch is slipping or something if you know please leave me a comment
    • By Randomneewb
      Hey guys, I have a 2003 cr125 I bought a couple weeks ago and I'm having a problem with it. The spark plugs die every about 15 minutes, with hotter plugs it will last about 45 minutes. I herd that if the timing is off it can over heat the plugs and burn out the the resistor. Is there any truth to that? The reason I thinks it's not fouling is because when the plug dies it gives no spark no matter how much you clean it, And it shorts out.
