need help fast torqure specs
what are the torqure specs on the 8 10mm triple clamp bolts that hold the forks on a 2008 kx250f:bonk:
I'm going off memory here, but i am 99% sure they are 15 ft-lbs. That's what i've been tightening mine to anyways :worthy:
•Route the cables and hose according to the Cable, Harness,
Hose Routing section in the Appendix chapter. •Unscrew the upper clamp bolts [A].
○Apply a non-permanent locking agent to the bolts. •Tighten the fork clamp bolts.
Torque - Front Fork Upper Clamp Bolts: 20 N·m (2.0 kgf·m,
14.5 ft·lb)
Front Fork Lower Clamp Bolts: 20 N·m (2.0 kgf·m,
14.5 ft·lb)
NOTE
○Tighten the two clamp bolts alternately two times to ensure
even tightening torque.
