rm250 problems
i have a 92 rm 250 that has just recently developed a hard spot through the stroke when trying to start it. any ideas what this problem might be? it seems to run fine after it gets started i dont want to dump thousands into it seeing as i only paid 800 bucks for it just hangin onto it as a spare/practice bike
Either that or is picking up in bore. If you are sure its not just TDC (try it with plug out to check) then pull pipe off and have a look at piston. it may give an indication if scored badly.
