counter balancer nut
I've only recently noticed references to the counter balancer nut.
Should a red loctite fix be done to this nut in addition to the primary nut? Should it be done ASAP?
If I was in the right case side,, yes, I would remove, clean and loctite the balancer nut. When working on the motor it always gets a drop. Would I pull apart a right case just for that??? No probable not. The balancer nuts have come loose on some DRZ's but not with a huge frequency.
Bottom line, if it's a fresh build or repair,, yes loctite it. If your in there anyway loctite it. :busted:
Great. Well then I'll hit it the next time in the right case. Any idea what torque spec to aim for?
rule of thumb........
any fastener that rotates needs loctite.
36 ft-lb
:busted:
