swingarm pivot bot siezed --2008 yz250
i picked up a beautiful 2008 yz250 a few months ago. the bike is amazing. one of my buddies just went through all kinds of trouble on his 2007 yz125. the swingarm bolt siezed and he couldn't get it out. he took it to a shop and it took them 5 hours to get it out!!! anyhow--this made me nervous.
the last ride i took on my 08 was a bit of a mudder. i decided to tear it down afterwards and grease everything up. the linkage & wheel bearings looked great and i cleaned them out and packed them w/ belray wp grease. then i tried to take off the swingarm. the darn thing is siezed!! i didn't beat the crap out of it for fear of mushrooming the end or destroying the threads. i gave it a good soaking w/ pb blaster and gave it a few more taps. it won't move. how could this happen on a seamingly new bike? how the heck do i get it out?? :busted: should i try heat? is this common on the aluminum frame 2-strokes or is this just bad luck?
thanks in advance!
lol happens way too often, the way i understand it is that the heat from the motor actually expands the bolt and it will almost weld itself to the alloy motor... but its actually very easy to get them out!
best way i found to remove these bolts is to go to a hardware store and buy about a two footlong piece of thread all and buy four or five nuts to thread on it! the use a socket or i used an old bmx bike peg or a couple washers that are about the same size as the bolt and put a fairly thick washer on the other side (the side the bolt will be pulled out from) and use a wrench and tighten the bolt down and it will pull the bolt right out! works everytime!
idk how well i explained it but if you pm me ill send you pictures of the one i made! it cost me about 7 dollars for the peices and parts to make it! and when you reinstall the bolt make sure you put some good water proof grease on the bolt everytime you reistall it and no more stuck swingarm bolt!
  • Similar Content
    • By faizakhtar125
      Hey guys I just bought a bike last night. So the seller said the bike will turn on but then die. We didn't try it because it was really late at night and it was raining (seat was wet). But he said if you bump start it, it will turn on and ride. So what do you think the problem is? I just want to make sure it runs... I probably won't be able to bump start it till Saturday (rain)... It's a four stroke, and I know absolutely nothing about them. Thanks.
    • By neonmarine
      Hey guys,
      I've used this forum as a "guest" for awhile now and I thought I'd share my build now that it's all coming together.  The primary purpose of this project is to help me train for roadracing my 2009 R1 at lower speeds as well as giving me a cheap alternative to racing the big bike.
      Here's what she looked like when I picked it up from a local shop.  Paid $800 cash for the bike as you see it with 17' rims, FMF pipe, EBC 250mm front rotor and clip on handle bars.
      Fits PERFECT!
      Shake down run at the Herrin Compound last summer:
      As she sits today:
    • By 125 yamaha guy
      i bought my yz125 from a dealer and they said that the clutch was broken so i bought it and it worked fine it would run move and everything and then it started to act up and now only first gear works barely though. when you put it in first it acts like its bogging down but its not and when you go into gears 2-5 it wont move i dont know whats wrong with it im assuming the clutch is slipping or something if you know please leave me a comment
    • By Randomneewb
      Hey guys, I have a 2003 cr125 I bought a couple weeks ago and I'm having a problem with it. The spark plugs die every about 15 minutes, with hotter plugs it will last about 45 minutes. I herd that if the timing is off it can over heat the plugs and burn out the the resistor. Is there any truth to that? The reason I thinks it's not fouling is because when the plug dies it gives no spark no matter how much you clean it, And it shorts out.
