320 rotoris it to thick for stock claiper
I have recently bought the 320 conversion kit from wheeling cycle supply and it seems that this rotor is to thick for my S calipers. I have done a complete s to sm conversion and I only have the brake left to do. Can anyone tell me if this rotor is to thick for my stock caliper and stock pads. Any help on how to install would be great. Thanks and I hope that I get some responses cause im lost.......
Not being an a$$....but did you push the piston back into the bore?
I think the S and SM use the same front caliper (they use the same pads at least), so I think you should be able to get it to work. Did you push the pistons back into the caliper a bit?
Like the others said, you need to widen the gap between the pads by pressing the cylinder into the bore. I use a big screw driver to gently do it, just be careful not to damage the pads.
I found that when I installed my 320mm rotor, the caliper wouldn't slide over when the pads were installed. Figured out that I needed to install the pads AFTER I had slid it over the rotor and before I bolted up the caliper. It's kind of a pain, but it is a very small price to pay to have better brakes.
Install the rotor, then install wheel.
Before putting the pads in, slide caliper over the rotor and don't bolt in place yet.
Install pads, be patient, it's kind of a pain. (Make sure that you have the pistons pushed in all the way before you install the pads)
Once you have pads installed, then bolt caliper in place.
Ta-da! Done
I did mine like Ryan, but I preinstalled the outside pad before slipping the wheel in then slid the inside pad into place after getting the rotor in the caliper.
I just kinda looked at fast but it seemed like the pads were pushed all the way in. Does it matter if you drain the brake fluid
Draining the fluid isn't necessary.
Is it the Braking wavey disc from Forrest? I have the same on my SM, the disc is approx 2mm thicker than the oe disc.
I had this same issue when I was installing mine. After lightly working it a bit with a screw driver, all of a sudden it clicked into place and was able to fit the caliper on.
Not sure if I should start a new thread or not, but since this one is on sm rotors then I have a question. I am converting my s to an sm as well and im having a hell of a time doing it:banghead: !! Well the front end is done so far and I am having trouble with the rotor spinning freely through the caliper. It is as it should be but then it gets pretty hard then easy and on and on. I am using all stock 07 sm parts and putting them on my 07 s. I tried to loosen clamps on axle to align and Im just not sure whats going on. I am using stock caliper with the sm rotor because it had more break pad left, Could it be that the pads from s need to conform to the new sm rotor? Rotor doesn't look bent at all but if it was it would probably be so minor I couldn't tell anyways. Any tips or suggestions? Maybe there is something else I shouldve done? Any help would be much appreciated. Gonna start the swing arm and rear end tomorrow, Any tips on that? Thanks.:busted:
I'd start by replacing the pads. Generally its not a good idea to swap rotors without swapping pads.
Okay, here was what the problem was. The stock s caliper does not have enough clearance for a 320mm rotor even with the sm forks. Because of this the edge of the rotor was hitting the caliper. All I did was swap the sm caliper mount to the other half of the stock s caliper and wa la.....Done! Perfect. Can't believe I didn't notice that last night. Hope this helps someone else who is doing the same thing.
The S caliper wasn't the problem, you were just trying to mount it to the SM fork with the wrong bracket.
Exactly. Had to switch bracket from the sm caliper to the s caliper. Pads and caliper from my s were in better condition than the sm.
How do you like the SM fork vs the S fork?
I'm having the same issue with my Drive Systems USA 320 Rotor Conversion. It seems to rub the caliper even without pads. Been consumed with the Corvette so really havn't tried to figure it out. I will post up pics once I have another look at it.
Ill let you know on wed. when I finish.:busted:
Mine rubs the inside of the caliper. No pads in and it rubs. Wonder if I got a bad relocator bracket???? It's like it is too thick.
Whats the brand and part number on the caliper relocation bracke??
  • Similar Content
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
    • By drzvfr
      I did the fix last night and took some pics and notes to make this easy on people that haven't done it and want more detail. Please chime in if you think I've missed something.
      Required Tools:
      Set of Allen wrenches
      #3 Phillips screwdriver
      small flat head screwdriver
      8 & 10 mm sockets
      13 mm open end wrench (I needed this to remove my skid plate)
      snap ring pliers
      gasket scraper
      compressed air
      Required Parts:
      New clutch cover gasket, Suzuki Part # 11482-29F00
      Tube or can of RTV sealant
      Oil filter and oil (if you plan to change the oil)
      1. Remove your skid plate (if you have one). I have a Tonn's skid plate and it was in the way.
      2. Remove right side radiator cover.
      3. Unbolt the rear brake lever. This will require removing a cotter pin on the backside of the bolt, and then the bolt itself. I was able to swing the lever far enough out of the way without completely removing it from the bike (see pic).
      4. Drain the coolant. This requires removing the radiator cap and the small bolt on the water pump, which has an aluminum washer on it. I rocked the bike from side to side to get most of the coolant out of the bike.
      5. The oil, two options here. You can either drain the oil and remove the oil filter or you can do what I did which is lay the bike on its left side to keep the oil from pouring out of the engine when you remove the clutch cover. I still removed the oil filter so I could clean the clutch cover with brake clean after scraping the old gasket off.
      6. Loosen the hose clamp on the coolant hose that attaches to the top of the water pump and fold the hose out of the way.
      7. Remove the water pump cover and the clutch cover by removing the bolts holding them on. Note that some of the bolts are of different sizes so keep track of which hole you pulled them from. Also, not all of the bolts need be removed, see the pic below.
      8. Remove the old gasket from the clutch cover and/or the engine with your gasket scraper. I then cleaned the clutch cover with brake cleaner as it was fairly oily.
      9. With your snap ring pliers, remove the snap ring from the plastic gear on the clutch cover seen here:
      10. Remove the plastic gear.
      11. Push out the metal pin and remove the washer underneath as seen here:
      12. With a screwdriver or whatever your preferred tool, remove the “E” clip as seen here:
      13. After removing the “E” clip push the water pump shaft out of the clutch cover.
      14. You will now have the part in your hand that needs fixing. Remove the porcelain gasket at the bottom of the shaft by blowing it with compressed air. Don’t not pry it with a screwdriver as it could damage the gasket. Mine was stuck fairly well so I sprayed some WD-40 on first to loosen it up.
      15. If you used WD-40 clean the shaft and gasket with some brake cleaner and then apply the RTV sealant to this area (I reused this pic as its perfect):
      16. Push the gasket back down flush on the shaft wiping away any excess RTV that may flow out.
      17. Reassemble the shaft into the clutch cover in reverse order as listed in steps 9-13.
      18. Place your new clutch cover gasket on the engine and then place the cover back onto the bike.
      19. Put the bolts back into the clutch and water pump cover and tighten equally. I could not find a torque setting for these in the manual so I snugged them evenly.
      20. Put the oil filter or a new one in the bike and put the oil filter cover back on.
      21. Re-attach the brake lever and tighten the bolt to 21 ft lbs. Be sure to install a new cotter pin on the backside of the bolt.
      22. If you drained your oil, refill the crankcase with the proper amount. If you didn’t drain the oil be sure you have enough in the crankcase from oil lost from removing the clutch cover.
      23. Let bike sit for 24 hours to let the RTV set up before adding coolant.
      24. Re-attach the coolant hose to the top of the water pump and tighten the hose clamp.
      25. Fill the radiator with a “Silicate Free” anti-freeze and put the radiator cap back on and tighten the radiator cap screw.
      26. Put the radiator cover and your skid plate back on the bike.
      27. You are done, go ride!
      This post has been promoted to a wiki
      Since I've been getting a few requests a week to e-mail the re-jet instructions word document (offered to send it to someone in old post that lives on) I thought I'd throw this post together. It is perhaps the one stop shop for 3x3 mod info: the master 3x3 post
      The 3x3 Mod
      So what is the 3x3 mod anyway? Well, this mod is basically re-jetting your carb and allowing it to run to its full potential. This mod can be done by even the most newbie of wrenchers out there. 3x3 refers to the size of hole that you will need to cut into the top of your airbox where your snorkel currently is. Don’t worry, you are not carelessly risking getting water into your engine by removing the snorkel. The bread and butter of the mod is the taper of new needle which you will get with your kit.
      Jet kits can be found through the TT here
      Scroll down to the bottom to find the right kit for your DRZ
      If you purchased a S kit for SM by accident don’t worry it will work (different jetting specs are used, just ask!)
      There are some great instructions outlining the procedure and here are two:
      bayoubikebruiser’s post is a nice one (Good Job BBB)
      Note that BBB followed the TPS sensor wire back and detached from the clip it there rather than removing the TPS off the carb.
      Another read is the attached word file (which i convereted to pdf and can be found here for your convenience) which has ‘been around the block’ to say the least.
      Sample Jetting recommendations (note: these are different for different elevations and different bikes)
      - 150 main jet (155mj for full exhaust system)
      - 25 pilot jet
      - 2nd clip on needle from top
      - 2.5 turns out on fuel screw
      - 140 – 142.mj (bigger for exhaust)
      - 25 pilot jet
      - 4th position from top
      - 2.5 to 3 turns out on fuel screw
      Burned’s fuel screw setting method:
      with the bike warm and idleing turn the fuel screw in till the idle drops/misses.then go back out till the idle peaks/smooths.
      this should happen between 1 and 3 turns out.
      if you end up at less than 1 turn you need a smaller pilot jet.more than 2.5 (or 3 turns on a cv) you need a bigger pilot jet.
      choose the appropriate size and retest.
      The 25 Pilot jet part number for TT is:
      So… now you have the info that you need, get to it! Your bike will sound better and rip a little faster; get ready to grin!
