04 525 EXC or 03 525 SX...thoughts?
So KTMTalk and me are having some difficulties getting me registered up... So I post here to inquire whilst I wait... Have an opportunity at these two bikes:
04 KTM 525 EXC. Comes with dirt tires, and some trick goodies (steering damper, other stuff I can't see in the 2" pictures on my phone).
03 KTM 525 SX. Comes with dirt and street tires/wheels/brakes.
Both have lights and street titles, both for roughly the same price (though the EXC is firm, and the SX is OBO). Those with KTM knowledge: thoughts on either?
I'm gonna try the CRF450R I just bought out at NJMP-Thunderbolt later this month, but I'm thinking so far that the bike probably isn't what I was looking for. I think I'm looking for something to tool around town on, woods/trails, hit up a local mx track just to screw around sometimes...a sumo track track day next year...and maybe not so much a road course bike. Something that's all-around good, but not great at anything - I'm not looking to race; ride-hard-put-away-wet reliability is a higher concern.
Any thoughts about either bike?
What are the odds that a set of Excel wheels I have for the CRF can be made to fit that EXC? Would that require entirely different hubs, or just spacers or something? I believe the Excel's are stock hubbed right now...
I read something online (which of course is gospel!) equating the CRF to the SX, saying that both were considerably more race-oriented...truth?
I would think the tranny in the EXC would be more versitile. Good luck.:busted:
Has the gearbox been upgraded to 6 speed on the SX??? It came as a 4 speed and was nearly useless off track so we commonly change them to 6.
EXC is a far more versitle bike
The '03 525sx came with a VERY lightweight crank. The power will be very abrupt compared to the '04 exc. They only made the 525sx like that for one year. If the '03 has the 6 spd.; go for it. If not; get the exc.
The sx really only works well on the track. It can be a handfull in tight offroad riding.
  • Similar Content
    • By Ponch
      I have a 2007 450 EXC that I recently installed a new clutch slave cylinder on. Per the 2007 KTM service manual it clearly states that the clutch needs to be filled with hydraulic oil, which I did (magura blood). That was yesterday. I went out to double check the level today and when I removed the cover, the rubber seal was all contorted and out of shape. I then looked at the cover and it's a Brembo clutch and says "DOT 4 brake fluid only".
      I flushed the line and the master cylinder about 7 times with DOT 4 brake fluid and there was no sign of the magura blood left in the system. My question is: other than the rubber boot on the master cylinder, what damage might have been done by putting in the hydraulic oil? It was in for about 24 hours.
      Thanks in advance for any advice!
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
