450skf 2009 transmisson help
wont shift into 3 or 4 when riding it took clutch case off shifter leaver is turning shift drum ok but when i ride it wont go into 3or4 no noises anyone have this problem any help would be nice
shooting in th ark, but have you checked the shifter, is it hitting the chain or jammed up? The other common things are the shift mechanism coming loose near the clutch. You may have to remoe the clutch hub to get to all the bolts that hold it together.
