klr 650 rear suspension adjustment????
hi my klr is to high for me and i wonder how easy it is to lower it down. I see there is a litle half inche bolt on the side of the shock. If i turn it would it go down and will i loose gaz in the shock if i want to put it back up??:busted:
Well i have a 93 klx 650 and the way i would adjust it is there is a spring underneath the seat with the shock inside it, u simply turn the washer/nut that holds into place. i don't know if its the same with yours but if u tighten it it will make the bike shorter but a much stiffer ride.
If you have the preload on the shock set to 3-5 it will have two affects on your bike. One will be the height and sag ( or lack of it) when you sit on it. The higher the number, the less sag and also it will affect your handling at higher speeds because it changes the rake of your front end.
I could not figure out why my 06 KLR650 started handling so poorly on the freeway until I was told the above info.
Also, if you really want it lowered, there is a lowering kit for the bike. I know a female who just put one on her 08. If you put the lowering link on, you have to adjust the triple tree ( front forks) a little to keep the correct rake on the front.
If you need more information go to the KLR650.net forum and there is good details on lowering the bike.
Good luck.
  • Similar Content
    • By Josh Munn
      Hi guys i recently bought a klr600 thats was running but had issues the guy i bought it off had fitted a manual timing chain adjuster but it had jumped a tooth and would hardly run i fixed that but it seems like the timing is retarded any one had this issue not sure what it uses as a pick up or if it has an auto advance. Cheers
      I also own a 81 xl185s, 81 xr250, and a 83 xr350. Cheers
    • By CantleyCustoms
      Hello guys,New to the forum.
      Quick question,I have a 1994 klx650c i recently purchased and am in the process of upgrading it.
      Have a trial tech vapor speedo ready to fit,however just wondering about the stock instrument gauges etc.
      Is it literally a case of unplugging the old dash and fitting the Vapor? Is the Dash used to complete the stock wiring circuit? e.g-if i unplug it and leave it unplugged is it going to effect the running of the bike? What about the dash lights,how would i go about wiring these up?
      electrics really isn't my strong point,got the basics covered but way too complicated for me.
      any help greatly appreciated,any more info you need please feel free to ask.
    • By rodrigonehme
      Hello, This is my first post and I'm new to TT.  I recently acquired a 2008 KLR650 (which by the way I absolutely love) and I'm working on adjusting my valves, I already measured its clearances and found this helpful online calculator: http://www.carguy.org/klr650/shims.html however I'm unsure of what the shim factory setting size is and it is essential to get the right shims. Does anybody know what the factory settings are?
      Thank you!
    • By RT_Chris448
      Recently we did a project bike with Dirt Bike Magazine's KLR650 and we were pretty excited about the results.  Check out the article on this fun project here:
    • By DougBurgoyne
      Hey guys,
      A super duper THANKS for all the help, laughs, and fun I've had here, and the bike I put together based on advice and lots and lots of reading material you've provided on what is the best vehicle forum I've ever encountered (been on many over the years). .
      Just when my bike was absolutely the bike I wanted it to be, my riding buddy (who is my father in law) bounced of his DRZ well up 4610 here in Oregon and broke his leg, and good. Tib/fib  job requiring rods, screws, plates, and a kitchen sink to put back together. If it wasn't for the MX boots I got him, and "forced" him to wear....there would have been all sorts of nastiness sticking out of the skin. No doubt about it, as both lower bones broke at sharp angles making spears inside his leg. As it was, everything was contained. He is going to be down for quite some time. I bought my drz to ride with him initially as he had a KLR650 and had an interest in backroad and moderate trail riding. On our first trip out (Brown's camp easy/mod trails) after about 10 times picking up his KLR with over-inflated 50/50 tires (mine stayed on 2 wheels all day long) he said "I need a bike like yours". Within a week he had his DRZ too! Then over the fall and winter we did all the mods and fixes to get them ready for this spring/summer.  It was kind of a miracle I even convinced my wife to let me get a dual sport bike. I'm 50 now, and have a degenerative vision disease called RP. Basically, I'm missing quite a bit of my vision field, but have decent vision straight ahead (unlike macular degeneration). I'm not in denial that good/full  vision is important for safe motorcycle riding on the street...and the reason I'm a 90/10 dirt/street guy. My argument was that we won't get hurt just poking around the woods, old man style, with occasional pavement work to connect trails (thus the need for dual sport over dirt bike).  Well, my father in law shot that theory down, but good!  He has dealt with so much pain over the last month, and met several dual sport riders in for riding injuries (some that make his look like a kid's day camp) that he decided he is out of the game. Unfortunately for me, that means I'm out of the game too. My wife is so worried I'm going to get injured badly, that it's not worth the fight. I don't want her and my daughter stressed and worried every time I go riding. My father in law was doing great on the roads and trails we've been riding. And just loved riding the DRZ. But he's 70 and looking at Jeep Wranglers with lift/tires for his forest adventures going forward. Not a bad call imo.  So...I've sold 2 DRZ's and a KLR in about 1 week (here in Portland OR, I could have sold 4 more DRZ's in the same time if I had them!).  His 1100 Honda shadow cruiser is on C.L. now as he is cleaning out the stable completely. Sad, sad day. It's only been a month since our last ride and I'm already missing the dirt big time. Even sold my daughters doodle bug. Oh well, life goes on.
      Take care guys, ride safe (inside your skill level), gear up...and have some fun for me!!
