CRF 450 wheels on XR650L
Has anyone tried to put CRF 450 wheels on an XR650L.
The front went on real easy with the 450 forks;) I don't know about the rear though.
I put some on a 650R, but not an L. See my post here for more info.
I was told by the guy who sold me Warp 9 SM wheels for my 650L that the hubs Warp 9 uses for the L are CRF hubs with spacers to match the 650L axle. Maybe you could call Warp 9 to verify this, then get spacers from them?
  • Similar Content
    • By Charles Mrizek
      This replaces part 9 in the exploded parts diagram for the 85 86 87 xr600r.
    • By XR-CJ
      I have this issue several times and cannot seem to figure it out. The four clutch spring bolts are the weakest bolts I have ever come across. I am not sure what the torque specs are, have the shop manual, have searched online and I can only guess it's around 4 ft/lbs. I have been told 8 and they seem to break every time around 7.
      What is the proper torque for these bolts?
      Should I find stronger bolts? I would still stick to the proper torque, but feel as if these things are butter.
    • By XR-CJ
      Prior to reassembling the case, I tested the shifting and it seems the center fork attached to the shaft seems to stick at the steepest section of the drum. I have cleaned and tested all forks and surfaces for smooth movement, tried it with silicone and oil. With very little help, it seems to shift ok, but without the help, it binds.
      Can I assume that once it is together the oil lines are attached and oil is added to the case, the binding will stop? I have tested every scenario short of assembling the entire motor.
      Should I be able to successfully test the shifting with the case apart?
    • By Charles Mrizek
      contact me if you're interested.
