08 CRF250x jetting question
I have a 2008 250x
Full DRD system
JD jet kit
Airbox cut
R and D fuel pump cover ( leak jet set at 50)
pink wire cut
altitude is 3000-4000 ft
needle red 4th clip
main 165 ( then tried 158)
pilot 42
airscrew 2 turns
Temp 25-35 deg C
This is my problem I have what sounds like a splutter or miss just before top , it is not the rev limiter as that kicks in at top RPM the best way to describe it is rrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr( only way on the keyboard)
its like a dull vibrating bark coming from the exhaust , am I too rich , same symptoms with 160 and 158 main .
Please help any advice will be appreciated , bottom to mid is awsome ,no problems there .
Also can someone shed some light on what the bike does or what to look out for if it is running rich or lean .
Thanks
On my '05 250x with a fmf, I was running a 170 main. Try going to a 168 and then 170 doing test runs to see if anything changes with each adjustment.
I need to know which direction to go , leaner or richer , do the symptoms I have sound like a lean condition or rich ?
Its more of a stutter , anyway I'm wondering if maybe its my float level , can someone perhaps shed some light on the float height and symptoms of incorrect float height.
