Is the DRZ400E Inlet Boot longer?
Hi does anyone know if the Drz400e intake manifold is longer than the SM stock one?
i have 2 different part # 13111-29F00 .......and 13111-29F30 this is intake manifold not air boot
IIRC, all model inlet & outlet tubes are the same length. only inlet & outlet diameters are different.
to suit the CV carb and the FCR
Ahhh ok that makes sense thanks
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
