04 KX 125 oil leak
Just noticed a few drops on the floor underneath the bike. I recently changed the crank case oil and now it appears to be leaking between the center case about half way between the bottom of the engine and the exhaust port. We have a race this weekend (Hare Scramble) and I tired to use some high temp copper seal RTV over the area just to get by for this weekend. Any suggestions on how to stop the leaking or do I need to split the cases and install a new gasket?
Mark C
Did you tighten the plug to the torque in the manual or just guess at it? I am hoping you didn't way over guess it.
Hopefully, you under - guessed it and it is leaking from the drain plug.
