2003 crf 450r
has anyone had issue with tranny oileaking around bottom bolts on tranny side
pics......
has anyone had issue with tranny leaking around bottom bolts on tranny side
When you say tranny bolts, do you mean the right side cover? If so that would likely be the gasket itself. The side cover gasket surrounds each bolt hole to keep oil from migrating down the bolt body and past the bolt head. That, or the bolts are loose.
thanx
When I say side cover, I don't mean the round one that covers the clutch components. Just want to make sure were on the same page. Anymore questions just post.
while i have cover off i was gonna replace crank seal, im losonig transmission oil and it looks like its going on engine side
