09' 20mm offset and fork height settings
Going from stock to 20mm offset on tripples on 09", has anybody found they had to move there fork heights lower or higher to compensate. Clicker settings?
put it at the first line on the fork tube
I have the RG-3s and I found between the first line and the second line on the forks works real well. I believe its 8mm and 102 mm of sag in the rear! It still does not handle like my 08 but its much better.
If you go by Motocross Action try....
comp-18out
reb-10 out
fork tubes -5mm up
fork oil- 340mm
this would be a good place to start from
what triples did you go with? did you get different tubes as well?
comp-18out
reb-10 out
fork tubes -5mm up
fork oil- 340mm
you cannot go by a general recommendation like mxa......tried their setting and it sucked.......they tell everyone to put the same spring rate in all their tests
Maybe cause mine is revalved, but those are pretty close to the setting I use. Im not the fastest guy on the track but ride 30+A class
I went with ride engeering. Complete stem and bearing included.
capdoogie, the Ride engineering clamps are reasonably priced, they are 22mm though rite? How did they perform?
mine was packing pretty bad w/those settings.........those were for the stock valving, if you had a revalve than its irrelevant and just coincidence that yours came out that way
It must a fluke that it worked out. The worst problem I have is my shock wanting to swap out every once in awhile. I actually writing this with a broken leg due to a swap out
ride makes the triple's in 22mm and 20mm
