YZ250f Jetting 01-09
I found this in the September 2009 issue of Motocross Action Magazine. I hope its useful to some people.
YAMAHA YZ250F JETTING:FROM 2001-2009
(9/2009)
As the original 250cc four-stroke of the modern era, the Yamaha YZ250F has the most development and refinement time of any bike of the track. Its jetting specs have evolved slowly over the last nine years (and the 2009 model isn’t all that different from the 2001 YZ250F). This is testimony to Yamaha’s thorough test program. They are very good at getting it right the first time then making it better with each passing year.
As with every jetting guide, there are caveats about temperature, altitude, riding style, hpo-ups, and personal taste. Our numbers are suggested starting points for motocross racers (the stock jetting, when changed, is included in parenthesis). The fine tuning is still up to you.
2001 YAMAHA YZ250F JETTING
Main: 175
Pilot: 42
Needle: OBELP
Clip position: 4th from top
Fuel screw: 2 turns (1-1/2 stock)
Leak jet: 95 (105 stock)
2002 YAMAHA YZ250F JETTING
Main: 178 (162 stock)
Pilot: 40
Needle: OBEKP
Clip position: 4th from top (4th stock)
Fuel screw: 2 turns (1-5/8 stock)
Leak jet: 90 (100 stock)
2003 YAMAHA YZ250F JETTING
Main: 178
Pilot: 42 (40)
Needle: OBELP
Leak jet: 100
2004 YAMAHA YZ250F JETTING
Main: 180
Pilot: 42
Needle: OBEKR
Fuel screw: 1-1/2 turns out
Leak jet: 90
2005 YAMAHA YZ250F JETTING
Main: 180 (182 stock)
Pilot: 42
Needle: OBELR
Fuel screw: 2 turns (1-3/4 stock)
Leak jet: 90
2006 YAMAHA YZ250F JETTING
Main: 180 (178 stock)
Pilot: 42
Needle: OBELQ
Clip position: 3rd from top
Fuel screw: 2-1/2 turns
Leak jet: 80
2007 YAMAHA YZ250F JETTING
Pilot: 42
Needle: OBEPQ
Fuel screw: 2 turns out (1-1/2 stock)
Leak jet: 80
2008 YAMAHA YZ250F JETTING
Main: 178
Pilot: 42
Needle: NFPR
Clip position: 5th from top
Fuel screw: 2-3/8 turns
Leak jet: 70
2009 YAMAHA YZ250F JETTING
Main: 178
Pilot: 42
Needle: NHKR
Fuel screw: 2-1/2 turns out (2 stock)
Leak jet: 70
i found it helpful! thanks! makes an easy resource when changing needles and such :busted:
Has anyone experimented with putting a larger pilot JET in a 2005 YZ250F?  I had some issues with mine a short while ago when it sat for a while.  I had to pull the bowl, clean the JET, bowl, etc. without having to completely pull the carb.  After I did that, it kicked over 2nd kick no problem however not a week later I had it at the track and had to kick it a lot more to get it to crank.  I haven't as yet checked the valve alignment, that is the next project because I'm having to run the idle way up to crank it then turning it back down to a normal setting to warm up.  Hopefully, I will be able to do that before I ride again.  I already have an aftermarket fuel/air screw in it so I will be turning it to the 2 setting, it is still at the stock setting as well.  I have started completely draining the tank and letting it run totally dry so as not to have it sit with gas just standing in the carb and engine.  That has seemed to help.
Any thoughts would be greatly appreciated before I start monkeying around with it.
Great information, none of the links I could find about stock jetting are still working websites. I have a 2002 YZ250F and I currently have a JD carb kit following instructions in it this is how mine looks for my elevation (1000ft).
Main: 185
Pilot: 42 pilot - I assumed to use a 42 since JD carb kit was based off 2001 stock pilot
Needle: JD blue
Clip position: 5
Leak jet: 35 (QS3)
