Yamaha 2001 Warrior Help!
I cant get it to start. I replaced the solenoid cause it was ticking and bought a new battery but didnt solve the problem. when i put the battery charger on one side (starter side) of the solenoid it starts but when i put it on the battery side nothing happens just clicks maybe its the switch but i took it apart and it seems fine. :bonk:
Sounds like a bad connection somewhere on the battery side. Check all your connections and fuses too.
yeah i cleaned all the connections and still the same also is there more than one fuse?
Might want to replace the battery cables. I've seen a lot of broken ones on the warrior. :bonk:
i have an 87 an 01 warrior the01 did the same thing i burned a starter up like 356 said conections expecialy batt to sellinoid an the other liittle conectr clean um good make sure crimped tigtin nuts then dielectric try it hit me bak
