Honda Starter problem?
I have a trx300 and the starter on it stopped working (at least I think it’s the starter). When I press the start button in makes a “clunk” noise and that’s it. I tried charging the battery a bit but that doesn’t help at all, can anyone think of something else I could try before I replace the starter?
Check the wiring running from the battery to the selinoid. If it's all good then you can try a jmper wire from the battery's + to the starter's + and see if it trips the starter farther than a clunk. The the problem will be with the selinoid or the wiring.
